Moome HDMI V1.3
BRIANJOHNSON
Posted: Mon Dec 14, 2009 1:06 am    Post subject: Moome HDMI V1.3
I have the Moome HDMI V1.3 and I cannot get it to sync to my NECXG 110LC. What is the setting of the swithes for this projector. Thanks Brian
MikeEby
Posted: Mon Dec 14, 2009 1:43 am    Post subject:
What resolution? 1080p 60Hz can be a problem using standard timings.
BRIANJOHNSON
Posted: Mon Dec 14, 2009 2:06 am    Post subject:
Well I think my Blu-ray player is set to 720p. I cannot get any picture to check resolution. Is there diffeerent settings on the dip switches? Thanks Brian
cinema mad
Posted: Mon Dec 14, 2009 3:50 am    Post subject:
Hi Brian,
Are you sure that your Blu-Player is'nt outputing 1080 @24p because that will cores your NEC not to sync due to being to low of refresh rate? .. Check and make sure the Player is set to 60Hz output...
Cheers...
