cpmorganesq
| Posted: Tue Dec 08, 2009 5:54 pm Post subject: Want to connect Blu-ray player to DWIN HDP500 projector |
I have a ten-year-old Dwin HDP500 CRT projector, which has (I believe) 1080i and 720 capability. I'm interested in adding a Blu-ray player to my system. The Dwin's TranScanner box has a DP-15 fifteen-pin input connector. I currently have an RCA set top box plugged into it, and I get a good hi-def tv image on my screen.
I'm assuming there are no Blu-ray players on the market with DP-15 input connections. Does anyone make an adapter to go from, say, component outputs to DP-15 male? If so, would I have any technical issues trying to do this?
I know the results won't be state of the art, but I'd still like to give it a try.
Thanks!
- Chris Morgan
benareeno
| Posted: Tue Dec 08, 2009 6:27 pm Post subject: |
Yep...the transcanner would be a thing of the past.
jkruger
| Posted: Tue Dec 08, 2009 6:30 pm Post subject: |
Wouldn't the transcanner be useful connected between the fury and the pj? Can't you set it to scale all the input to be the same size on the screen?
cpmorganesq
| Posted: Tue Dec 08, 2009 7:30 pm Post subject: |
Thanks, everyone -- I'll get a Fury!
| Posted: Tue Dec 08, 2009 7:37 pm Post subject: |
Make sure you get the Fury3, and note that it is shipping next month only. If you get a Fury2, you'll also need to get a GammaX for negative sync.
The Transcanner has an RGB passthrough I think. If you still have analog video sources, keep the Transcanner, and route the Fury's output through the RGB passthrough.
