Cube
| Posted: Sun Dec 06, 2009 3:41 am Post subject: Specifications of old Sony IFB v1.72? |
I got a used Moome DVI card but I don't know exactly what it can do. The PCB is labeled "SONY IFB V1.72 2005.11.30 BY moome" and it has DVI and YPbPr inputs on the front with a two-way switch.
I can't find the specifications for this card anywhere. In particular, I'd like to know:
1. What exactly do the LEDs indicate?
2. Does the DVI work with HDCP?
3. Does the YPbPr input get transcoded as 16-235 or 0-255?
4. Can the DVI input take YCbCr, and does it expand 16-235 to full range? If it does, does it clip RGB input too?
If anybody can point me to a datasheet or something I'd really appreciate it. Thanks.
cinema mad
| Posted: Sun Dec 06, 2009 7:55 am Post subject: |
He is the only Document released for the IFB-DVI that I know of..
Cheers...
| Description: |
 Download |
| Filename: |
sony dvi instructions.pdf |
| Filesize: |
4.57 KB |
| Downloaded: |
777 Time(s) |
Cube
| Posted: Tue Dec 08, 2009 2:15 am Post subject: |
Thanks. Now I'm wondering what exactly that jumper does. Does anybody else have information?
| Posted: Tue Dec 08, 2009 2:18 am Post subject: |
| Cube wrote: | | Thanks. Now I'm wondering what exactly that jumper does. Does anybody else have information? |
The jumper is in the PDF instructions.
JP1 shorted for D50, G70, G90
JP2 shorted for PS1270/71 switcher
JP3 shorted for VPH 12xx series projectors.
Cube
| Posted: Tue Dec 08, 2009 2:24 am Post subject: |
I understand, but I wonder what the jumper actually does. It's currently in the JP2 position but it was installed in a 1272 projector.
cinema mad
| Posted: Tue Dec 08, 2009 2:56 am Post subject: |
The Jumper pins changes the voltage to suit 12xx projectors or G series ....
Cheers...
moome
| Posted: Wed Dec 09, 2009 1:07 am Post subject: Re: Specifications of old Sony IFB v1.72? |
| Cube wrote: | I got a used Moome DVI card but I don't know exactly what it can do. The PCB is labeled "SONY IFB V1.72 2005.11.30 BY moome" and it has DVI and YPbPr inputs on the front with a two-way switch.
1. What exactly do the LEDs indicate? RED--> indicate card is active, Yellow indicate component selected, Green indicate DVI signal is active
2. Does the DVI work with HDCP? YES
3. Does the YPbPr input get transcoded as 16-235 or 0-255? YPbPr go 16-235
4. Can the DVI input take YCbCr, and does it expand 16-235 to full range? If it does, does it clip RGB input too? NO, only accept RGB 0-255
it is the first type of moome card, we totally have four version:
1. IFB-DVI
2. IFB-HD
3. IFB-FULLHD
4. IFB-FULLHD V2
thanks
