cornelius
| Posted: Sun Nov 29, 2009 9:36 pm Post subject: NEC 6PG XTRA Can't register 1080i@72Hz signal |
I have 1080i@60Hz locked in now, and when I change it to 1080i@72Hz using my scaler the picture is shifted to the left, and I get unregistered signal. I bring the picture back over to the center, everything looks good, but when I try to save it I get unregistered signal. I have tried making a new signal from scratch, and I get the same problem. Maybe i'm missing something simple? I'm not sure, but the judder at 60Hz bothers me a little.
Any ideas???
Elaine Benes
| Posted: Tue Dec 01, 2009 1:44 pm Post subject: |
As soon as you change to the new signal, do you try hitting Adjust, then Signal Entry, etc. etc. before you do any changes ?
cornelius
| Posted: Tue Dec 01, 2009 7:05 pm Post subject: |
Yeah, that worked. I was adjusting the image, then trying to save it as a new input and it wouldn't let me.
Thanks Paul.
P.S. I found that remote for the Runco doubler, and sent it with your DVE disc.
Elaine Benes
| Posted: Tue Dec 01, 2009 10:58 pm Post subject: |
| cornelius wrote: | Yeah, that worked. I was adjusting the image, then trying to save it as a new input and it wouldn't let me.
Thanks Paul.
P.S. I found that remote for the Runco doubler, and sent it with your DVE disc. |
Superb, glad to hear it worked. That is one honkin' bedroom HT you have, btw...*(thanks for mailing me that stuff)
