I'm scoping out giant LED flat panels
Posted: Sun Nov 22, 2009 5:44 pm    Post subject: I'm scoping out giant LED flat panels
One for the living room and if that works well perhaps one hanging where the DaLite screen resides.
dturco
Posted: Sun Nov 22, 2009 6:00 pm    Post subject: Re: I'm scoping out giant LED flat panels
Does this mean your not going to be using that almighty AmPro anymore? Shocked Laughing
And no to CRT? Very Happy
http://www.hulu.com/firefly
jask
Posted: Sun Nov 22, 2009 6:07 pm    Post subject:
more info?....
Posted: Sun Nov 22, 2009 6:41 pm    Post subject:
A scope is indeed handy to repair those LED units.
Posted: Mon Nov 23, 2009 12:17 am    Post subject:
A scope would be nice but a extended warrantee would be a better investment.
My 4600HD is on it's third set of tubes. It has been the most reliable projector I've owned to date. I would not consider trading it for any other 9"LC projector as they are all getting old. Right now there's nothing wrong with it. It's working perfectly as it always has. I am going to buy a LED flat panel for the living room. The life expectancy is way more than a plasma or LCD and the power usage is way less than any other flat panel. Next time you go to BB, feel the face of a LED. Then go and do the same thing with any other flat panel. Christ, you can fry an egg on the face of a plasma that's been running all day.
Posted: Mon Nov 23, 2009 1:47 am    Post subject:
The LED's are basically an LCD but using led lamps for backlighting instead of CCFL. They still use inverters for the lamps. Are you sure the power consumption is less? They do have 240hz scan rate and supposedly local dimming which allow certain areas to be dimming while other stay bright allowing for an enhanced black level.
Here's part of the guts from one:
Posted: Mon Nov 23, 2009 2:17 am    Post subject:
Why would you say they still have an inverter, Mac? If a TV is LED-backlit, there shouldn't BE an inverter, because there's no fluorescent lamp... And from everything I've seen and read - they do use significantly less power... As in almost half. What makes you skeptical?
Posted: Mon Nov 23, 2009 2:39 am    Post subject:
This is from a factory training manual. I didn't show the whole page because I have to be careful of what I post. I haven't had my hands in one yet but have chatted with some that have. I'll see if I can get more info. The reason I question power consumption is because the basic functions between the two are almost the same. I'm curious if anyone has this data. The red circle and word inverter is in the manual. I didn't put it there.
Posted: Mon Nov 23, 2009 3:23 am    Post subject:
One suggestion I will give you Chip is, there are 2 types of LED backlighting. One is full panel lighting and the other is edge lighting. The edge lighting is only LED's around the outer edge with a diffusion panel to spread the light. The edge LED is not capable of local dimming where the full panel LED is. And as I said before, local dimming gives you better black levels which also gives you better color reproduction.
Posted: Mon Nov 23, 2009 3:30 am    Post subject:
I think I've been confused about "LED" flat-panel displays. I was thinking they were basically DLP back-projection sets that used pulsating LEDs instead of a lamp and a color wheel. (My brother has one of these, a Samsung model.) Certainly LEDs as a light source would be more efficient than the hot lamp. I think they are making LED projectors like this, but apparently most/all of them so far are just low-lumen portable projectors.
But apparently they're also making LCD displays that use LEDs for backlight instead of CCFL, and that's what you guys are talking about here?
dturco
Posted: Mon Nov 23, 2009 3:34 am    Post subject:
I found this interesting. Slight explanation of LED technology.
http://www.nytimes.com/2009/06/18/technology/personaltech/18basics.html
donaldk
Posted: Mon Nov 23, 2009 3:42 am    Post subject:
Oh, you're not looking to get a LED panel, you're looking to get an LCD TV. Otherwise I would have suggested Mitsubishi and Barco. You'll still see screendoor though on the smallest LED spacing around, 4.5 mm. That new small prototype by Mitsubishi at the recent Ceatec show looked interesting aswell, ecept for its low lifeexpectancy.
Posted: Mon Nov 23, 2009 10:31 am    Post subject:
Yep, you do see screen door but only if you're close enough to get snot on the screen. I see scanlines from the same distance so what's the difference. I took a tape measure with me when I looked at the first one to see exactly what it would look like from the seated position. Even with glasses on, no SDE. The living room one is the test bed while I'm burning up the current set of tubes in the beastie. When those tubes are toast I'll be faced with the following options.
1. Re-tube a +30,000 hour set at a estimated cost of about $3,500.00 or replace the set with another CRT and that's not going to happen.
2. Put the $3,500.00 towards a JVC RS-2 or better which is a likely alternative. The lamps in the RS-2 are half the price of the Sharp LCD lamps I was buying in my first projector.
3. Switch to a LED flat panel, brand to be decided at that time.
Don't get me wrong. I love my AmPro. It's just getting a ton of hours on it and it's just a matter of time. I can see it all now. It will have 35,000 hours on it and things will start to go wrong on a regular basis. At that time I'll take a ragging from people like Pete who will say "See, I told you AmPro's were a piece of crap" Rolling Eyes
David_Web
Posted: Mon Nov 23, 2009 2:18 pm    Post subject:
"Why would you say they still have an inverter, Mac? If a TV is LED-backlit, there shouldn't BE an inverter, because there's no fluorescent lamp..."
CCFL is DC to AC which means an inverter.
LED are DC to DC (or DC to current) which means an inverter.
"Oh, you're not looking to get a LED panel, you're looking to get an LCD TV."
True, that always bugged me when people get it wrong, can't blame them though as advertising makes it a LED panel.
One have to wonder if you should call the others CCFL panels then.
Posted: Mon Nov 23, 2009 4:27 pm    Post subject:
OK, I'm thoroughly confused. I understand an inverter for DC-to-AC for CCFL. But, why with DC-based LED's do you need an inverter? I thought an inverter was specifically to convert DC to AC. Or, are they using some sort of modified AC LED in a high-voltage AC circuit or something?
Posted: Mon Nov 23, 2009 8:39 pm    Post subject:
Pete hasn't been around much so if you like I can carry on with his tradition...... Very Happy
Posted: Mon Nov 23, 2009 8:59 pm    Post subject:
I am working on detailed info for you guys. I'm just waiting on some documents.
Posted: Mon Nov 23, 2009 10:16 pm    Post subject:
I'm working on giving a good-ole-boy AKA redneck a new toy to play with but he doesn't answer his PM Laughing
Posted: Mon Nov 23, 2009 10:57 pm    Post subject:
HOLY CRAP!!!!! I thought I answered that PM. I guess I was so excited I couldn't tell if I actually answered it or I just imagined I answered it.
Anyways, I'm working out the details on which weekend and then which day I will be there. Mr. Green
I should know by weeks end. Thumbs Up
Posted: Mon Nov 23, 2009 11:35 pm    Post subject:
I thought there was something a southern muck. Laughing
Page 1 of 6
