BigDLondon
Joined: 02 Mar 2008 Posts: 32 Location: London, Ontario, Canada
| Posted: Fri Nov 20, 2009 11:39 pm Post subject: Barco BD801s input 3 problems |
Hi Guys and Gals
I've got an Barco BD801s and a 1040 lite.My 1040 lite was plugged into input 3 than we went to watch a blueray and the projector went all crazy like it was out of sync and fuzzy picture.Lucky I found a vga to 5 bnc cable on Kijiji for 10 bucks and hooked it up to input 5.So my question is.Is it a big problem to fix input 3 or should I just not bother?Thanks BigD
_________________ I Love My Barco BD801s and not just because my wife tells me I do.
akajester
| Posted: Sat Nov 21, 2009 2:38 am Post subject: |
Should be able to just swap in a new card. Maybe Curt can test and/or repair the one you have. Pretty sure the pj will run just fine without the card in.
BigDLondon
| Posted: Sat Nov 21, 2009 2:49 am Post subject: |
Thanks for the reply akajester.I'll check on that later coz it looks great right now on input 5.BigD
| Posted: Sat Nov 21, 2009 6:06 am Post subject: |
Port 3 not required. You could just leave it out. Don't leave it in the projector if the card is bad. Port 5 on that projector should give you as good if not better picture than a standard port 3 card??
BigDLondon
| Posted: Sat Nov 21, 2009 2:24 pm Post subject: |
I don't know which card is the port 3 card even if I wanted to take it out.My projector is mounted on the ceiling.Thanks for the tip.
| Posted: Sat Nov 21, 2009 5:39 pm Post subject: |
I've got spare port 3 cards out the wazoo. Email me. Once you get the new card, you'll see which one it is.
Cheers!
akajester
BigDLondon
| Posted: Sat Nov 21, 2009 9:57 pm Post subject: |
I've emailed you Curt about a replacement.Big D
