digitalayon
| Posted: Fri Nov 13, 2009 2:41 am Post subject: how do I "kill" the lines? |
I will be making my own custom screen and I am new to this CRT stuff with 6 months experience. So bear with me....Shows in HD and movies seem to be giving me constant different sizes and I end up with bars on the top and bottom unless I adjust resolution. What must I do for a constant size. Some movies fill it and some don't. Could it be my basic Power DVD software?
| Posted: Fri Nov 13, 2009 4:32 am Post subject: |
Movies have different aspect ratios. Some will fill a screen, some are cinemascope, and will leave black bars top and bottom.
The best way to deal with it is to make adjustable masking out of black felt.
| Posted: Fri Nov 13, 2009 4:14 pm Post subject: |
Depending on how anal you are about the correct aspect ratio, there's a couple of ways to do it:
1) Set different memories up for different apsect radios, and stretch or squeeze a bit to keep the height constant.
2) Overshoot the images a bit, and use the electronic blanking in the set to crop the top and bottom of the image.
| Posted: Fri Nov 13, 2009 5:28 pm Post subject: |
I'm one of those anal people who thinks you should see it like the director intended you to see it. Would you crop a Monet so it would fit your living room wall better? Stretch a Picasso so it fits your hallway better?
Option #1 would look like ass on scope movies.
Option #2 reduces resolution and you miss a big portion of the composition.
Don't molest the movie to make it fit your screen!
| Posted: Fri Nov 13, 2009 5:29 pm Post subject: |
| ecrabb wrote: | Would you crop a Monet so it would fit your living room wall better?
SC |
Damn rights I would. THe fireplace is in the way otherwise, and it's cheaper to cut canvas than rebuilding brick.
