daves123
| Posted: Mon Oct 26, 2009 9:03 pm Post subject: NEC 6pg xtra - Contrast & Brightness adjustments. |
I just finished the tube swap on my 6pg xtra, and fired it up. The previous owner had the brightness & contrast settings very high. I've gone through the menus, and can find the white balance for each individual tube, but can't find an overall brightness & contrast setting. Do they exist? I'd like to turn it down while I adjust everything and figure this beast out.
| Posted: Mon Oct 26, 2009 9:34 pm Post subject: |
Press PIC FUNC.
daves123
| Posted: Mon Oct 26, 2009 9:44 pm Post subject: |
That was it, thank you. New problem. When I turn the projector on, the raster on the blue tube lights up, and stays lit, even when the pic is muted. When I bring up the grid to align, the blue shows no image, but the raster is lit up. Does this sound like someone messed around with the g2? Or could it be something else?
Elaine Benes
| Posted: Tue Oct 27, 2009 12:19 am Post subject: |
Assuming you have a signal going to it, get an image up then just turn the AKB on/off to bring that blue in line.
If the AKB doesn't tame it, it gets more complicated...
| Posted: Tue Oct 27, 2009 1:27 am Post subject: |
Does the blue work at all?
Or is the raster hard on all the time? If so, you have a dead neckboard. Blue Xtra neckboards fail a lot, I think it's due to the fan blowing dust on the back of them.
| Posted: Tue Oct 27, 2009 2:22 am Post subject: |
One of the cables going to the blue CRT socket has come off the socket or off the video board that they connect to. Tight wiring, stupid NEC design. I'll betcha a donut one has come off. If not, then you bent a pin on the CRT when putting the socket on.
daves123
| Posted: Tue Oct 27, 2009 2:38 pm Post subject: |
It looks like one of the cables from the neckboard came off the video board, it was half on, so I plugged it back in all the way. Hopefully this fixes it. I'm gonna put everything back together, and see it that fixed it.
daves123
| Posted: Tue Oct 27, 2009 5:37 pm Post subject: |
That didn't do it. I also turned the akb on, then off again, and it was still the same, so I swapped out the neck board, turned it on, the raster was still wonky and then it just started working. I guess it was a combination of everything.
Thanks for the help
wallace123456
Joined: 14 Aug 2006 Posts: 2236 Location: Northwest VA area
| Posted: Wed Oct 28, 2009 1:46 am Post subject: |
So, is the projector working "good" now?
wallace
_________________ Life Is Good, But BBQ Is Better! BBQ Competition Team
daves123
| Posted: Wed Oct 28, 2009 8:10 am Post subject: |
| wallace123456 wrote: | So, is the projector working "good" now?
wallace |
So far, so good. All i've brought up on screen was a crosshatch pattern. I'm sure i'll have more issues along the way.
I'm going from an ECP to the NEC, so i'm sure there's a bit of a learning curve ahead.
