digitalayon
| Posted: Fri Oct 23, 2009 4:38 am Post subject: setup question |
ok I have a RuncoDTV933 I do not have the remote. But I see that i can make a cable and control the unit with a pc. Is this true or am I just smoking dope?
Ben851
Joined: 13 Sep 2008 Posts: 221 Location: Ottawa, Ontario
| Posted: Fri Oct 23, 2009 11:01 am Post subject: |
Yep - you can control it via a PC. Your runco is actually an NEC 6PG, so this is what you need:
http://curtpalme.com/NECPG_PCControl.shtm
I controlled my NEC XG with a PC to get it up and running - but to really dial it in you're going to want to invest in the actual remote control for it..
_________________ Thanks,
Ben
| Posted: Fri Oct 23, 2009 11:14 am Post subject: |
I have a Runco 900 here. I made the control cable but it would not work. I just ended up buying the remote.
