samcguire
| Posted: Mon Oct 19, 2009 8:34 pm Post subject: Need Suggestions for New HTPC |
My wife wants my HTPC to reposition it for other (her) uses. So far, I have enjoyed a very high WAF and would like to keep it that way. With newer hardware available, it may be time to give in (gracefully) and build me a new one.
The HTPC is used only for a front end to feed my NEC 6 PGXtra. All ripping, encoding, file storage, etc. is performed by other machines on my wired gigabyte network and delivered to the HTPC. Over ninety % of the content is ripped VCR & DVD. I tend to use Gigabyte motherboards & Nvidia video cards (not a requirement) and send the audio to a receiver for decoding (toslink). Software is Powerstrip and XBMC.
This is a dedicated HT, so it doesn't need to "blend in" with the decor or be in a mini case. Desktop would be fine.
I would appreciate your suggestions on hardware/software for a new front end.
samcguire
akajester
| Posted: Thu Oct 22, 2009 7:43 pm Post subject: |
I built my new htpc earlier this year. It's a gigabyte ma770 motherboard with amd quad core processor, 4gb of ram, ati 4350 graphics card and some 1.5tb hard drives. I recently added a bluray drive. I put this in an old desktop case I had laying around. I also upgraded the power supply to a 680watt for more sata power. I'm running windows 7 on it (previously xp) and it's been rock solid. I would highly recommend using Media Portal as the front end. http://www.team-mediaportal.com/ Be prepared to fall into the rabbit hole!
All my media (dvd's, cd's, blurays) is ripped into mkv files and played off this machine.
I was also using ac3filter to output audio over spdif using the on board audio and it sounded good. I heard from others here that analog outs are way better. I ordered some premium 1/4" to rca adapters from monoprice and doing analog 8 channel audio using the realtek onboard audio and it sounds awesome! it definitely seems more rich than the spdif.
I hope this helps you out!
