New ATI video gamma works great!
Thor
Posted: Thu Oct 15, 2009 10:36 am    Post subject: New ATI video gamma works great!
I got the new HD 5750 for my HTPC yesterday, and played a little around with the new settings on the card. And I must say that I have never before had a image that looked so good on my CRT's. Very Happy (9500LC Ultra)
My problem have always been getting the details to stand out, without sacrificing the black level, but now I can with the video gamma adjustment.
One thing though I wondered about, was that I was not able to see the below black stripe in the PLUGE setup? I had no problem seeing it on my old 4850 card.
Morten.
akajester
Posted: Thu Oct 15, 2009 11:51 am    Post subject:
Thor, are the gamma adjustments different than previous versions? I remember in the catalyst panel you can move a curve, but it doesn't allow individual point adjustment. Or low end boost only, etc.
Thanks!
Thor
Posted: Thu Oct 15, 2009 12:48 pm    Post subject:
Thanks!
I have never before been able to adjust gamma on the video with ccc, only on the desktop, but that didn't affect the video?
This is a normal slider where you can set it from 0.5 to 3.5 in 0.5 steps.
akajester
Posted: Thu Oct 15, 2009 2:12 pm    Post subject:
oh I see. What version of catalyst drivers? Thanks.
Thor
Posted: Thu Oct 15, 2009 2:48 pm    Post subject:
It is 9.10, only released for the 58xx/57xx series yet.
Elaine Benes
Posted: Fri Oct 16, 2009 11:55 pm    Post subject:
Just curious if there is some option to choose between full computer output or video level output for the card ? And maybe its on video output and thus won't show below black ? Just a stab ....
MikeEby
Posted: Sat Oct 17, 2009 12:03 am    Post subject:
What player are you using?
Thor
Posted: Sat Oct 17, 2009 9:13 am    Post subject:
I'm using TMT3.
I got it to show the black stripe by working with the video brightness. It seems that the output from this card i somewhat darker than my 4850 was. Maybe it's because of the dedicated 1.3 HDMI output?
I can change the output between 4:4:4 YCrCb and full RGB. And to be honest I'm a little confused what is best? I have heard that full RGB gives most colors, but the videosignal from Blu-ray/DVD is encoded in the YCrCb domain, and that converting it to full RGB should actually degrade the image a little??
Posted: Sun Oct 18, 2009 10:09 am    Post subject:
It has to be converted to RGB somewhere, either in the PC or the HDMI card.
Test it and see.
I wonder if the new gamma control will work on all AMD/ATi cards? Might be worth getting TMT working - it won't run on my system, piece of crap.
MikeEby
Posted: Sun Oct 18, 2009 11:15 pm    Post subject:
Test it and see.
Yeah...TMT doesn't like film rates...Except for maybe 24p...When I tried it at 72Hz it was really screwed.
Posted: Sun Oct 18, 2009 11:28 pm    Post subject:
I didn't have any issues with TMT running 96i.
My issue now is I can't get it to run at all since rebuilding my PC. I think it needs the Xonar HDMI "Splendid" part of the drivers...I don't want to install that piece of bloatware crap as I use analogue out.
MikeEby
Posted: Sun Oct 18, 2009 11:49 pm    Post subject:
"Splendid".....WTF?...Marketing...Arg!...Going OT here...is the Xonar Deluxe worth it?...A distributor I buy from is offering seed units for a decent price....I'm tempted to try the direct to power amp audio like you all I use that htpc for is Movies and some HD-TV shows.
Posted: Mon Oct 19, 2009 12:27 am    Post subject:
No, the drivers are sh*t. Woeful. Worse than crap.
There's a HT Omega Claro card that might have better drivers.
MikeEby
Posted: Mon Oct 19, 2009 1:06 am    Post subject:
Thanks...I'll save the 160 bucks for now.
donws
Posted: Thu Nov 19, 2009 12:16 pm    Post subject:
Thor wrote:
I'm using TMT3.
Thor,
How do you get component (YCrCb) out of 5750? I just got a 5770 which includes a DVI-I/VGA adapter and I haven't tested it yet, but I assume it only outputs RGB. I don't see any settings in the latest Catalyst GUI to choose between component and RGB. Did I miss it?
Don
Thor
Posted: Sat Nov 21, 2009 1:31 pm    Post subject:
donws wrote:
Thor wrote:
I'm using TMT3.
Thor,
Don
The YCrCb is through the DVD/HDMI output, up to my Moome HDMI card, not analog. I can't remember exactly where in Catalyst you set it, and I think it is different from monitor to monitor, weather it is shown in the GUI or not.
donws
Posted: Sun Nov 22, 2009 11:18 pm    Post subject:
Thor,
Thanks, my mistake. I misread your original post and thought you were somehow getting analog component (YPrPb) out of the card. My goal is to feed the PC/Radeon 5770 into a component input of my whole-house video matrix switch, a Russound VM-1. I suppose I could use the card's HDMI out through a HDFury2 or 3 to achieve this, but then I'm not sure if overscan (e.g., missing Windows task bar) would become an issue. I'd rather not have to mess with software such as PowerStrip if it can be avoided.
Don
yonexsp
Posted: Fri Jan 08, 2010 2:09 am    Post subject: Re: New ATI video gamma works great!
Morten.
We should say a big thanks to my buddy CS at AMD who made this happen, also with the help of all you guys and the folks on AVS. I spent some time last year writing a short Requirement Spec after getting feedback and reviewing all the problems the CRT community had with Gamma. I sent the doc to CS and AMD used it it putting this feature out!
They are a great company, and read this forum and others and value what we say. ATI got my vote Smile
Ken./
Posted: Fri Jan 08, 2010 5:34 am    Post subject:
Does custom resolutions work with a 5xxx card?
I read on the Powerstrip forum that it's not working as ATi hasn't released the info that Entech need.
Without a custom res capability I cannot buy a 5xxx, and I want a 5750, I'll have to go Nvidia.
Oh, and the gamma thing no workee with my 2600XT card.
yonexsp
Posted: Mon Jan 11, 2010 1:38 pm    Post subject:
Timings solution: http://gamers-underground.com/tech-chat/32178-how-set-custom-resolutions-radeon-5xxx.html
Also the Gamma only works on the new 5xxx cards.
