antorsae
| Posted: Sun Oct 11, 2009 10:44 pm Post subject: Top/bottom key not working |
I am re-doing my blend and while setting geometry on one PJ I've noticed that TOP ant BOTTOM KEY adjustments do not do absolutely anything to the image. I've swapped CLMs with the same results.
Any ideas? The rest of the geometry controls work on (except BOW which I don't know b/c I don't use).
Rgs - Andres
| Posted: Sun Oct 11, 2009 10:46 pm Post subject: |
Hello
Try swapping the Geom/Focus board. I have spares if needed.
antorsae
| Posted: Tue Oct 13, 2009 11:54 am Post subject: |
Thanks Tim.
It's weird... I swapped the Deflection processor board in my CLMs and then top/bottom pin worked again... this is so weird... what are the chances of two deflection processors failing exactly in the same way?
