HD Fury 2 with an old Mit 55"
twstrickland
Posted: Sat Oct 03, 2009 10:45 pm    Post subject: HD Fury 2 with an old Mit 55"
I have a Mit 55", I am using a Tivo Series 3. When I set the Tivo to 1080i fixed my HdFury 2 works amazing, but it will not work with my Xbox nor my DVD player. Any ideas? I got a new Amp (Denon 2310) with the intention of running everything through it and then to the TV. The Tivo worked, none of the others did. I tried to run both to the TV using the HdFury2 but they didn't show a picture. Help, the picture lookes so good using the HDMI and the HD Fury 2.
Posted: Mon Oct 12, 2009 4:39 pm    Post subject:
Make sure that sources you connect are set to 1080i only. If your sources are set to "source direct" or auto they may switch to 1080p and your Mits will not support that. Mits CRT's can only accept 480 i/p and 1080i. If any other source goes to the Mits you will get either no picture or scrolling.
