Problem with Sony G90
FoLLgoTT
Posted: Tue Sep 29, 2009 5:51 pm    Post subject: Problem with Sony G90
My Sony G90 doesn't start up anymore. Crying or Very sad
It just does nothing when I press the power on button. The display on the back is black and no LED lightens up. Even the light of the built in remote doesn't work. But when I insert the power cable I hear this typical slightly audible sound which shows that there is power on the cable. I checked the two fuses on the back and they measured ok.
Does anyone has any idea?
Thanks!
Nils
Posted: Tue Sep 29, 2009 5:52 pm    Post subject:
Yes, the power supplies (one of them) is most likely bad. THese are very tricky to repair, but I have spares or can repair yours.
Let me know if you want to send the two boards in.
FoLLgoTT
Posted: Mon Oct 05, 2009 8:05 pm    Post subject:
Thanks for your answer. Smile
I measured a bit and I found out that R4 at the F board is defective. The service manual describes it as a fuse resistor. Now I have to find a replacement which doesn't seem to be easy.
Do you know what could have caused the fusing?
Nils
FoLLgoTT
Posted: Fri Oct 16, 2009 3:51 pm    Post subject:
Thread can be closed. I changed that resistor and the G90 works again. Smile
Nils
ilias
Posted: Fri Oct 16, 2009 3:54 pm    Post subject:
Take a 2000VA UPS, for the dream machine!!!!!!!!
