Confusion over High Def Audio
jarseneau
Posted: Fri Sep 25, 2009 3:00 pm    Post subject: Confusion over High Def Audio
With the advent of BR and HD-DVD came the audio formats; Dolby TrueHD and DTS Master Audio. I've been seeking a definitive answer as to what my options are to fully take advantage of the formats. After much seeking I believe I have it sorted out but if someone knows better I would welcome corrections.
What connections will work between player and processor/receiver, etc. On wikipedia I found this:
Dolby TrueHD may be transported to AV receivers in 5.1 or 7.1 channels, at full uncompressed quality, in one of three ways depending on player and/or receiver support[1]:
• Over 6 or 8 RCA connectors as analog audio, using the player's internal decoder.
• Over HDMI 1.1 (or higher) connections as 6- or 8-channel Linear PCM, using the player's internal decoder.
• Over HDMI 1.3 (or higher) connections as the original TrueHD bitstream, with decoding done by the AV receiver.
To me that boils down to 2 options:
  • analog if your player is so equipped and no HDMI on the receiver.
  • HDMI is the only digital delivery system. Setting the player to LPCM will use the players decoder (if so equipped), Setting the player to Bitstream will use the receivers decoder (I'm guessing all are capable if equipped with HDMI and claim audio processing).
My question is, Is my interpretation correct? Are all HDMI equipped receivers able to decode DD TrueHD? If my player can decode TrueHD and DTS MA, does it matter what the receiver can decode as long as it has HDMI?
Jerry
Posted: Fri Sep 25, 2009 3:29 pm    Post subject:
Not all hdmi receivers are equipped to decode Dolby trueHD. However to decode true hd you must have either ...
a player that decodes the format and sends out 7.1 analog thru rca jacks.
or
a receiver w/ both hdmi inputs and the decoding capability.
my 2c
jarseneau
Posted: Fri Sep 25, 2009 6:48 pm    Post subject:
So far all my sources have 5.1 analog outputs with decoders going to a Sunfire Theater Grand pre/pro.
Toshiba XA2- HD DVD
HTPC with Xonar audio card for playback from BR and the harddrive.
Pioneer SACD/DVD-A player
This all goes to a Zektor CVS4 multichannel switcher which is an interesting exercise in cable management Very Happy.
The only HD component not doing the analog connection is the PS3 using fiber-optic audio/ HDMI video. Since the HTPC is doing great for the BR, I'm not concerned about the PS3 as the games sound just fine.
Jerry
