menec
| Posted: Fri Sep 18, 2009 10:12 pm Post subject: Question about Marquee 8500 Focus Boards |
Hello,
I got two different focus boards from a marquee 8500
assembled 44/95
Focus Board (FCM) 50-2034-02P
assembled 45/97
Focus/Geometry Board (FGM) 50-0354-01P
what exactly is the difference between the two boards.
which one is the "better" one to use, or what are the advantages.
menec
| Posted: Fri Sep 18, 2009 10:44 pm Post subject: |
wow, that was fast. Thanks!
Is there any documentation listing the serial numbers of ultra-boards and none ultra-boards? Which boards despite the FCM are different between the Ultra and standard version? I have some more spare boards here, maybe I have enough parts to build an Ultra
menec
| Posted: Fri Sep 18, 2009 11:48 pm Post subject: |
Basically I have two of all the boards except HDM and the CLM (blinking lights issue I was never able to fix). So maybe it would be worth checking.
menec
| Posted: Sat Sep 19, 2009 12:04 am Post subject: |
If with "motherboard" you are referring to the big board with lots of plugs on it (P14 etc) which connects all the other boards, yes - I also have two of them. But as I said, I don't know if one of those is an "ultra" board.
Regarding the CLM I tried everything from cleaning, to swapping chips, changing the battery and even replacing the caps. To be precise it's not the CLM but the DPB which is broken. CLM works fine with a replacement DPB.
| Posted: Sat Sep 19, 2009 12:08 am Post subject: |
| menec wrote: | If with "motherboard" you are referring to the big board with lots of plugs on it (P14 etc) which connects all the other boards, yes - I also have two of them. But as I said, I don't know if one of those is an "ultra" board.
Regarding the CLM I tried everything from cleaning, to swapping chips, changing the battery and even replacing the caps. To be precise it's not the CLM but the DPB which is broken. CLM works fine with a replacement DPB. |
yeah I have one of those too, i never figured it out. I think its one of the non removable chips that goes bad, I need to make two more extender cards to be able to scope the entire CLM and DPB, But for the DPB i ordered the wrong connector I need the Board to stand up straight I ordered the flat type with a right angle, Doh!!!
Athnaasios
