wbamb83392
| Posted: Wed Sep 16, 2009 12:49 pm Post subject: Marquee 8500 problem |
I picked up a pair of inexpensive retired Marquee 8500 projectors a while back that I never got around to using until now. One of them works fine, but the other did some strange things when I first plugged it in. The red tube briefly illuminated on its entire surface, then went black. The other tubes did nothing. When I peer through the lenses with the projector running I see only one single faint dot on each tube toward the bottom center. When I push the menu buttons on the remote, nothing appears. It seems as though the beam isn't scanning since there is no noise or illumination on the tubes except for the dot. None of the diagnostics lights are illuminated. I've never seen this projector display video.
Does anyone know what the most likely problem is? I hope it's loose connection or a common problem I can fix with a soldering iron. If its not fixable, then I have another question. The working projector has burnt tubes and the non-working projector has nice tubes. Is it more efficient to swap electronics, or tubes?
thanks,
Eric
| Posted: Wed Sep 16, 2009 1:04 pm Post subject: |
First clean all the contacts through out the entire Pj, also it be a good time to clean all the boards as well with denatured alcohol and a soft tooth brush.
pay special attention to the removable chips and smaller daughter boards especially on the Control module (CLM). reseat the HVPS and the LVPS as well. Open the LVPS and blow out any dust that may have accumulated. then report back.
to your question about swapping parts, since you have one PJ that works its easy to now swap boards in and out of the non working to the working PJ to find out which board is faulty. Start with the power supplies.
http://www.avsforum.com/avs-vb/showthread.php?p=14952911#post14952911
wbamb83392
| Posted: Thu Sep 17, 2009 2:30 pm Post subject: |
Reporting back...
1. Tested bad PJ. Previously the red tube flashed, then showed only one dot per crt. Now it displays nothing.
2. Cleaned contacts and connectors. No change, no dots.
3. bad PJ LVPS works fine
4. bad PJ HVPS works fine
5. bad PJ CLM reproduces original problem in good PJ, displays dots
It seems that there are two problems, one causing the display to be one dot per crt and another new problem causing nothing to display at all. Should I continue swapping, or is it likely that one bad board damaged another? I don't want to have two bad projectors.
-Eric
| Posted: Thu Sep 17, 2009 2:34 pm Post subject: |
Keep swapping boards. I'd suspect a neck board or the VIM. I can repair the one(s) that are bad.
| Posted: Thu Sep 17, 2009 6:30 pm Post subject: |
| wbamb83392 wrote: | Reporting back...
-Eric |
Ok Clean all the chips and contacts on the CLM first before testing any other boards.
Did the good PJ go back and work ok after you put the good CLM back in? Just want to make sure it didn't do any damage but they usually dont .
Once you clean all chips go back again and try it. if it still doesnt go on then keep that CLM in the bad PJ and put the HDM from the good PJ into the bad PJ and see if it lights up.
wbamb83392
| Posted: Fri Sep 18, 2009 2:17 am Post subject: |
Ok I've swapped just about everything from the bad PJ into the good PJ and it still works: VIM, HDM, HVPS, LVPS, all three crt socket boards, the entire heat sink/board assembly, and the focus module. The only bad part so far was the CLM, but the good CLM does not cause the bad projector to function. It turns on and displays no error lights, but there's no picture at all and no static electricity noise like the good PJ makes.
I haven't swapped the HV splitter yet, or the board above the CLM. It looks like I'll have to completely disassemble and reassemble both machines for each further swap, so feel free to offer any shortcuts.
-Eric
| Posted: Fri Sep 18, 2009 3:44 am Post subject: |
Check the entire non working pJ's mother board for any screws or metal parts that may have got caught in one of the open connectors, especially up against the back plane. So yes do a complete tear down and rebuild of the non working PJ, use the good CLM once its all back to check and still clean the bad clm's chips and contacts first and test it once more before the tear down just in case. i had a clm not work in one PJ but worked in its original PJ after i did all the cleaning of the chips, not sure why but it only worked in that PJ? Weird huh?
wbamb83392
| Posted: Sat Sep 19, 2009 1:48 am Post subject: |
| Nashou66 wrote: | Check the entire non working pJ's mother board for any screws or metal parts that may have got caught in one of the open connectors, especially up against the back plane. So yes do a complete tear down and rebuild of the non working PJ, use the good CLM once its all back to check and still clean the bad clm's chips and contacts first and test it once more before the tear down just in case. i had a clm not work in one PJ but worked in its original PJ after i did all the cleaning of the chips, not sure why but it only worked in that PJ? Weird huh?
Athanasios |
I swapped the color correction board and the HV splitter, and both were fine. With the exception of the main board, back plane board, and CLM, all electronics from the bad PJ have been swapped to the good PJ and work fine. I disassembled the bad PJ down to the bare chassis, cleaned and inspected everything, and reassembled. I noticed that the right side ribbon cable to the heatsink assembly was only on one row of pins. I must have done that when going through the connections the first time. After reassembling the PJ, I got a LVPS error light. The connector on the right side of the back plane board was shifted down one pin. Once that was fixed, the PJ turned on and I heard the static electricity noise it hadnt made before ,but absolutely no illumination on the tubes. There is the same result with both CLMs.
Would the misconnected ribbon cable damage the heatsink/board assembly? I'll probably have to swap that again to make sure. After all this work and no progress I'm pretty frustrated. Maybe I can sell all these good parts and get my money back.
I live in a very remote area where chip pullers aren't available, so I'll have to try cleaning the chips some other time.
-Eric
| Posted: Sat Sep 19, 2009 2:48 am Post subject: |
well the HV crackle is good!! I did the same thing once with the back heat sink ribbons and no issues after. Have you checked the Voltage at the P14 plug?
This is the heater element voltage, it should be 6.35 volts or close to it. if its higher than the tubes could be shot. One more thing are there any error lights
on the CLM now that it works or on the LVPS front panel?
And for shits a giggles after you hear the HV crackle wait a minute and hit the contrast button and raise it with the up arrow , you never know it might be all the way down. Also check to make sure all the G2 lines are on the correct PIN on the tubes!!!! look at the marquee set up guide here on curts site its the Top pin in the key slot of the tube socket.
wbamb83392
| Posted: Sat Sep 19, 2009 5:29 am Post subject: |
| Nashou66 wrote: | well the HV crackle is good!! I did the same thing once with the back heat sink ribbons and no issues after. Have you checked the Voltage at the P14 plug?
Athanasios |
I swapped the heatsink assembly again, and it still works. Voltage at P14 is 6.43 according to my cheapo meter. I was very careful to connect the G2 lines to the top pins. The voltages as labeled on the main board are fine. The ribbon cables are good too. Hitting the contrast button does nothing.
-Eric
| Posted: Sat Sep 19, 2009 12:12 pm Post subject: |
6.43 is kinda high and it could have cooked the tubes over time but I am not 100% positive that the voltage you see is enough to do that, some other person care to comment? One thing you can do next but its more work to see if the tube is cooked is to swap a tube from the bad to good PJ and see if it lights up. Oh one more thing did you switch the Vim from the good PJ to the bad one? also use the good CLM in the Bad one together with the VIM.
Revox
| Posted: Sat Sep 19, 2009 12:22 pm Post subject: |
No, 6,43V isn't to high. Its under +-5%! I red something in the bulletin messages that you should start thinking about this voltage when its under 5,5 or over 7V.
When the tubes of one PJ are burned hard (can you make a picture of them?) stop searching, offer all parts, whatch a movie instead of "wasting" time.
I understand your problem of failure search, i am always motivated in finding a bug too but afterwards i look back and namend myself a time waste basket!
wbamb83392
| Posted: Sat Sep 19, 2009 4:02 pm Post subject: |
| Revox wrote: | No, 6,43V isn't to high. Its under +-5%! I red something in the bulletin messages that you should start thinking about this voltage when its under 5,5 or over 7V.
I understand your problem of failure search, i am always motivated in finding a bug too but afterwards i look back and namend myself a time waste basket! |
Well, I tested P14 in the bad PJ, but the power supply has been swapped. I tested P14 with the original power supply and it is 6.68v. If the tubes had been damaged by high heater voltage, would all the tubes have failed? The first time I turned on the projector, the red tube flashed and then all that was displayed was a single dot in each tube, which is a problem I can cause in the good projector by swapping the CLM. The working projector has the tubes burned black with the image of a computer desktop, but the broken projector has only faint text burns meaning it probably malfunctioned before the idiots could make their marks. Later today I'll swap the green tubes and see what happens. When I bought these (stupidly without inspecting them) I couldnt imagine that someone would abuse a $20,000 video projector to do the job of a $100 slide projector, then sell one broken and one burned unit as "good condition". Live and learn.
-Eric
Revox
| Posted: Sat Sep 19, 2009 4:14 pm Post subject: |
My M was used 800hours and has a very bad green tube. I didn't wonder about this:
They put G2 to 80 and set the contrast and brightness very high. Then they destroy half of the light output using polar filters...
| Posted: Sat Sep 19, 2009 5:28 pm Post subject: |
| wbamb83392 wrote: |
-Eric |
yeah 6.68 is way way to high, that is probably the issue, and it will cook all tubes since that suply is used for all tubes.
Going back to the dot problem. You said the dots were on all tubes near the bottom of the tubes right? not near the top. I dont think that is spot kill issue cause the beam usually collapses in the dead center of the tube. that sounds more like the "dot fix" issue in one of the service bulletins.
And Revox, this is from Tim Martins site, he is the expert on the Marquee PJ as he worked for them.
j) If you have a digital voltmeter, take the top gray covers off and try to measure the filament voltage across connector P14 (see PIC 1), it should not exceed 6.50 volts dc when the unit is powered up. P14 is on the mother board just below the cover for the blue neck board. Filament voltage above 6.50 for a few hundred hours will destroy the cathodes in the CRT electron guns. We can repair your LVPS filament power supply alone or as part of our Marquee Fan Noise Reduction mod; e.mail us for details.
So even 6.48 is too high for my own comfort, keep it below 6.35 and your fine.
wbamb83392
| Posted: Sun Sep 20, 2009 3:06 am Post subject: |
| Nashou66 wrote: |
Athanasios |
The voltage must be adjustable then, if I can somehow keep it below 6.35. I have a feeling it is the top secret LVPS ajustment mentioned in the pages elsewhere on this site dealing with the marquee internals. I don't know why it's a secret, people who own CRT projectors obviously love adjustments.
I just swapped the tubes, and they work fine. The problem must be in the main board, backplane board, or wiring. Now I'm going to set it up outdoors and watch a movie under the stars. Although the problem remains a mystery, I'm proud that I managed to disassemble and reassemble these projectors without destoying them in the process.
Thanks for all your help, it has been much appreciated.
-Eric
| Posted: Sun Sep 20, 2009 3:24 am Post subject: |
| wbamb83392 wrote: | The voltage must be adjustable then, if I can somehow keep it below 6.35. I have a feeling it is the top secret LVPS ajustment mentioned in the pages elsewhere on this site dealing with the marquee internals. I don't know why it's a secret, people who own CRT projectors obviously love adjustments.
-Eric | there's no "top secret" and adjusting it won't help you because the adjuster, called a trim pot, is bad. I bet dollars to donuts your machines are 1996 or early 97 vintage. 6.48 is really still too high and 6.7 is just plain bad. Also, with the bad trim pot the voltage drifts all over the place. might be 6.48 now and 6.8 later. Ideally now that you have 1 working machine you should send your LVPS to someone and have it fixed.
| Posted: Sun Sep 20, 2009 3:41 am Post subject: |
Drags right here is the procedure for fixing the heater voltage.
Re post from my Marquee thread:
http://www.curtpalme.com/forum/viewtopic.php?p=106293#106293
The first installment I thought should be the Heater filament fix . this is to save the tubes
from over voltage to the heater elements in the tube causing premature failure.
remove the LVPS from the projector and open up the case being careful to remove all
connectors before completely opening. Locate the 6.35 voltage trim pot on the section
that houses the fans. a 470 ohm metal film resistor and a 20ohm trim pot is needed.
here is a close up pic.
remove the old pot that causes the drifting of the voltage as shown here
then I wrapped one end of the resistor around the existing resistor as shown, I did
this backward for the pics, I should have cut the trace first as in the next pic after this
one.
this pic you can see the trace cut and the resistor soldered to the other
resistor, i found it easier to keep the lead on the resistor then cutting it after its all done.
Then I fed the other lead through the whole that the cut trace goes to. Make sure all the
old solder is removed so the pin from the trim pot can also fit.
Now with the new trim pot in place.
Back side of board showing lead from resistor and trim pot leads.
Solder the pins from under and put power supply back together and test the output before
you connect P14. trim pot to get as close to 6.35 as you can.
While you have the cage for the power supply out you can cut the screen area to allow better
airflow and it could also help reduce and turbulent noise, i used a pair of metal snips then a file
to smooth it out. I also added dynamat to the inside stop any vibrations in the chasis.
A fan noise post will also be in this thread too.
Parts needed: I get mine from Newark:
http://www.newark.com/jsp/search/productdetail.jsp?SKU=62J1506
http://www.newark.com/jsp/search/productdetail.jsp?SKU=94C3568
Elaine Benes
| Posted: Sun Sep 20, 2009 12:50 pm Post subject: |
| wbamb83392 wrote: | | Nashou66 wrote: |
Athanasios |
-Eric |
I've run into a 9500LC which displayed the same characteristics of your machine, it belonged to a buddy of mine, in the end he ended up getting an 8500 chassis and swapping everything into it except the motherboard and backplane, we used the super secret passcode (which I lost years ago to a computer virus...)to change the info screen to say 9500LC instead of 8500 and he's been happily using it for years since then. Our best guess, not confirmed because of all the work to just confirm something we'd fixed, was the small chip on the backplane which stores set basics had been corrupted or damaged in some way...
| Posted: Sun Sep 20, 2009 5:28 pm Post subject: |
Nash i like your P14 fix. I've been doing something almost identical except resistor on bottom. I really don't like the fixed resistor method. I have one here done by someone else and it's at 6.23VDC. You would think that's fine but it throws a dimmer picture. I think nailing the 6.35 within +/- .01 is the way to go and you need a trim pot for that.
