drice1234
Joined: 07 Oct 2006 Posts: 1309 Location: Allen, Texas
| Posted: Tue Sep 15, 2009 2:51 am Post subject: Sony blue adjustment help |
I recently installed my backup D50 which had lower hours than my current unit. The problem that I am having is that the blue display is more green than blue. This is most noticeable when viewing the channel guide screen. Is there any adjustment available to get this more blue than green. I have attached a few pics that give a general idea of what it looks like. The second is the channel guide with the projector which is quite a bit more aqua color looking than the picture shows and the first is the channel guide on a normal CRT tv. Thanks for any suggestions.
Dan
| Description: |
| Filesize: |
60.42 KB |
| Viewed: |
4156 Time(s) |
| Description: |
| Filesize: |
37.58 KB |
| Viewed: |
4157 Time(s) |
drice1234
| Posted: Thu Sep 17, 2009 12:20 pm Post subject: |
Bump. No suggestions on how to take care of this issue? Come on guys. If I had a gun wielding liberal communist beer drinking pot smoking hamster up my ass I'd have a least 20 suggestions by now on how to get it out.
Dan
| Posted: Thu Sep 17, 2009 2:14 pm Post subject: Re: Sony blue adjustment help |
| drice1234 wrote: | I recently installed my backup D50 which had lower hours than my current unit. The problem that I am having is that the blue display is more green than blue. This is most noticeable when viewing the channel guide screen. Is there any adjustment available to get this more blue than green. I have attached a few pics that give a general idea of what it looks like. The second is the channel guide with the projector which is quite a bit more aqua color looking than the picture shows and the first is the channel guide on a normal CRT tv. Thanks for any suggestions.
Dan |
The blue tube can't change color. Each tube only emits a color that is a product of its phosphor and color corrected lenses. Assuming RGB input, if you have too much blue in a regular image with all three tubes running than you have a bad gray scale that needs adjustment. If you are running component, then you may have a bad gray scale, or you might have the color/tint set wrong.
akajester
| Posted: Mon Sep 21, 2009 4:29 pm Post subject: |
| drice1234 wrote: | Bump. No suggestions on how to take care of this issue? Come on guys. If I had a gun wielding liberal communist beer drinking pot smoking hamster up my ass I'd have a least 20 suggestions by now on how to get it out.
Dan |
Have you gone through the grayscale calibration on your d50?
drice1234
| Posted: Mon Sep 21, 2009 5:47 pm Post subject: |
| Quote: | | Have you gone through the grayscale calibration on your d50? |
I have not yet. I did set the bias back to factory default and that seemed to help some. I am trying to get my new hdmi receiver working now and then will try to tackle the grayscale after that. I read the instructions very briefly. Do I need a meter to do this? I do have the Avia DVD but have not broke the seal on it yet.
Dan
akajester
| Posted: Mon Sep 21, 2009 7:06 pm Post subject: |
Yes you'll need a colorimeter of some sort. It would be near impossible to adjust by eye. Even a cheap spyder2 would get you decent results.
| Posted: Mon Sep 21, 2009 7:14 pm Post subject: |
| akajester wrote: | | Yes you'll need a colorimeter of some sort. It would be near impossible to adjust by eye. Even a cheap spyder2 would get you decent results. |
True, but following the manual for gain and bias will get it a lot closer than what it is now. That's assuming the green tube isn't really worn, which can also have the set display what you posted above.
| Posted: Mon Sep 21, 2009 8:11 pm Post subject: |
I'm with Curt - you can get the grayscale in the ballpark without a meter. This machine isn't even in the right city!
My votes are a very worn green, a bad green neck board amp, or something awry with a component source cabling. I'm thinking about component cabling because of how the green field is green, but the white text is magenta (no green). Seems like a colorspace-ish thing - like the source is cabled RGB, but the input is setup for component. Still, let's eliminate source for a moment. Two questions, Dan:
A) Can you get the machine to display the white warmup screen looking anything close to white?
B) Have you looked at the green tube to evaluate its condition?
drice1234
| Posted: Mon Sep 21, 2009 8:37 pm Post subject: |
| Quote: | A) Can you get the machine to display the white warmup screen looking anything close to white?
B) Have you looked at the green tube to evaluate its condition? |
Yes, the white warm up screen looks fine and I have not taken the lens off to look at the tube but this unit has 1800 hours on it compared with the 4800 on the one I replaced. When I am in the menu screen the left side of the menu has a blue background that looks like it should. My video chain is Satellite and PS3 to 3x1 switcher, 40' hdmi cable, HDFury2 with GammaX and short 5 bnc connector that came with the HDFury to the projector. I have input A set to RGB. I have also changed the input to YPrPb and switched the HDFury2 to this setting and obtained a picture. I had the HDFury2 at the head end for awhile and utilized a long 5 BNC cable while I replaced the bad 40' hdmi cable. I do have 2 spare D50's that I can swap parts out with if there are any suggestions.
Dan
| Posted: Mon Sep 21, 2009 8:44 pm Post subject: |
| drice1234 wrote: | | Yes, the white warm up screen looks fine |
OK, cool - we can eliminate a tube or neck board, then. That leaves a source/cabling issue, or perhaps something in the video input section of the projector. I was thinking you could switch input cards, but the D50 doesn't have a removable input card, does it? I'd try a composite or S-video source next just to potentially isolate where the color shift is happening (and isolate/eliminate an RGB/component issue), but after that is about where my troubleshooting expertise runs out. Curt, your turn!
akajester
| Posted: Mon Sep 21, 2009 9:43 pm Post subject: |
Boy, knowing up front that it only happens on one source would've been helpful, haha. I hope you get it narrowed down. Sure would be awesome if it was just a cable issue.
drice1234
| Posted: Mon Sep 21, 2009 10:22 pm Post subject: |
I'll connect the composite out of my satellite receiver and the component out of the PS3 up tonight and see if the problem persist on these sources.
drice1234
| Posted: Tue Sep 22, 2009 12:45 pm Post subject: |
I connected the composite out of the satellite receiver and the guide display is still more of an aqua then blue. I changed out the A board and the problem remained. I ran out of time but will connect an lcd display on the end of the chain to make sure that the guide is the proper color on this.
