Extron RGB 190 problems, won't stay on
akajester
Posted: Sun Sep 13, 2009 4:42 pm    Post subject: Extron RGB 190 problems, won't stay on
I got this Extron RGB 190 and when I plug it in the power light flicks on then goes off when plugged in. Could this be anything? or do you think a different power supply would fix it? I'm using an old extron 118 and I'm hoping the 190 will be better, If I can fix it.
thanks!
Posted: Sun Sep 13, 2009 4:44 pm    Post subject:
Sounds like a power supply problem. Check the caps, etc.
akajester
Posted: Sun Sep 13, 2009 7:57 pm    Post subject:
Ok, I get the dumba$$ of the year award. it works just fine, the POWER LED is also the "signal" LED. So, once I fed it a signal and had the cable right, the power led came on. Smile of course after I swapped the power, etc. oh well, problem solved.
