How to Remove E-board on a G70?
Gary W
Posted: Sun Sep 13, 2009 12:18 am    Post subject: How to Remove E-board on a G70?
Hi all,
Just turned the projector on, switched the input on the receiver from satellite to ps3 and it shut down with a code 35. Did a search here and discovered what triggers this fault code. Also tried to press down a bit on the board in case it came loose.
So, I can't seem to remove the board. I released the top lock tabs but it's still in tight. Anyone know what I need to do next?
Thanks (failure with a room full of friends - no doubt...)
Gary
Gary W
Posted: Sun Sep 13, 2009 12:49 am    Post subject:
I figured it out. Ceiling mounted and need to buy a long screw driver. Just walked out of the ht, shut the door and am going to forget about it for now.
Posted: Sun Sep 13, 2009 1:15 am    Post subject:
No, the board pulls straight out. Yank on it if it sticks, but there's no screws holding it in.
Gary W
Posted: Sun Sep 13, 2009 2:28 am    Post subject:
Thanks, Curt. I did a search and read that it was between the red and green tube so I guess it isn't the one with the black plastic sides. Glad I walked away and didn't try!
Where is the card located?
Thanks a lot!
Gary W
Posted: Sun Sep 13, 2009 3:09 am    Post subject:
Got it, board's out thanks.
