NEC XG G2 adjustment
picree
Posted: Sat Sep 12, 2009 5:37 pm    Post subject: NEC XG G2 adjustment
I've scanned through the manual (most all is dedicated to menu controls). I've looked through the "Hooking it all up" (FAQ) and can't find an answer. Simple question for those who know. KennyG has posted a procedure here in the FAQ section called "NEC XG G2 Calibration" that says, in part:
10) Set "AKB" test switch to test position.
11) Set your DMM (digital multimeter) to VDC and measure test points TP7404 (red G2) TP 7504 (green G2) and 7604 (blue G2) verify the voltage is 2.5 vdc +/-0.1 vdc...if not try small adjustments of "Contrast", if that doesn't help, call a service tech.
12) Adjust Black Bias to 50 (default) this is just a "rough setting".
13) Set "AKB" test switch back to Normal position.
Which board contains the AKB test switch and which board has the TP7404, 7504, and 7604 test points? Where exactly are they located? Thanks for any help. Confused
Curt
MAIN THEATER: (JVC RS2000; Yamaha UDP-LX500; Yamaha RX-V2400; Lumagen Radiance Pro, Vertex)
SECOND WII-ATER: (BG808; WII; Oppo 971H; Moome external box; BG-DVI transcoder; tse gamma box; Extron)
Posted: Sat Sep 12, 2009 11:53 pm    Post subject:
They are on the Video Out/Gain boards, in the card cage at the rear.
Just measure for now. NO TWEAKING.
picree
Posted: Sun Sep 13, 2009 3:50 am    Post subject:
Oh yeah...understood...I read the manual and the comments here. NO TWEAKING! Thanks. Smile
picree
Posted: Sun Sep 13, 2009 11:25 am    Post subject:
Follow-up. What does the AKB test switch look like? Is it labeled? Is it a jumper? I'm going over to a friends house and it would be good to know in advance to keep us moving. Tks.
Posted: Sun Sep 13, 2009 12:39 pm    Post subject:
It's a tiny little switch. Sideways on the vertical circuit board.
