Finally mounted my Chief EVCM-100D lift, and it doesn't work
daves123
Posted: Sat Sep 12, 2009 3:00 pm    Post subject: Finally mounted my Chief EVCM-100D lift, and it doesn't work
I finally got it mounted and I can't get it to lower. It says on it not to lower until on ceiling. So I attached it to the ceiling, plugged it in, turned it on, loosened the clasps and pressed the down button and it makes a noise like it's running but nothing happens. If I press the up button, it doesn't make any noise, but it is already in the up position. If anybody has any experience with these things, I would appreciate your help.
Posted: Sat Sep 12, 2009 3:31 pm    Post subject:
Did you unlatch the bottom half of the lift?
daves123
Posted: Sat Sep 12, 2009 4:27 pm    Post subject:
Yeah, I undid the clasps on the sides that attach the bottom to the top. When the clasps are undone, the safety is released allowing the unit to lower. If I press the safety in it stops functioning. When I let go of the safety, the unit makes a humming sound, not sure if this is the normal sound of the motor, or the sound of the motor being burnt out.
Posted: Sat Sep 12, 2009 4:39 pm    Post subject:
sounds like it's unwinding, maybe the cable is snagged. Try pulling on the lower portion while someone puhes the down button.
daves123
Posted: Sat Sep 12, 2009 4:51 pm    Post subject:
Just tried that, and it won't budge. I guess i'm gonna have to take it down, and rip it apart.
daves123
Posted: Sat Sep 12, 2009 5:52 pm    Post subject:
Ok, so I took the lift down, and took it apart. I spun the gears by hand, plugged it in, turned it on and she worked. I guess the gears were sticking from sitting for a long time.
