jcoles
| Posted: Wed Sep 09, 2009 11:28 pm Post subject: marquee 9500 set up |
Could you give me some advise on setting inputs on my Marquee 9500?
I have two input cards:
Input 1 HTPC
Input 2 Satellite and Bluray via HDFury
When I make adjustments and lock the settings I find when I go back to them the settings haven't held and I have to adjust size, phase and convergence all over again. What am I doing wrong?
I had Mike Parker put in his modified neck and VIM boards and the pictures are stunning, when it works. He even modified my HDFury.
| Posted: Thu Sep 10, 2009 12:29 am Post subject: |
Utilites, source set-up. Make sure ASR is OFF.
jcoles
| Posted: Thu Sep 10, 2009 3:24 am Post subject: |
Thanks, but I already had done those things.
| Posted: Thu Sep 10, 2009 11:30 am Post subject: |
Check the battery then on the CLM, it should read close to 3 volts, if not you need a new one. for now you can use the Marquee Librarian program and save all your settings before you shut it down and then load them after turn on. I know its not a fix but till you find a battery if that is what it is its a way to save time of re-convergence and size adjustments.
nashou
jcoles
| Posted: Thu Sep 10, 2009 2:39 pm Post subject: |
I'll try replacing the battery. Is it a difficult battery to find and will I lose settings if I remove it?
| Posted: Thu Sep 10, 2009 4:26 pm Post subject: |
| jcoles wrote: | | I'll try replacing the battery. Is it a difficult battery to find and will I lose settings if I remove it? | tim Martin @ Etech had a bunch at one time.
