ViVo
| Posted: Tue Sep 08, 2009 10:28 am Post subject: Horizontal Shrink and shift to left |
Hi All
I’m using a upscaling DVD player , HDfury 2 and GammaX into the PC input of my new RCF 6200 DL CRT Projector
When I set my DVD player to up-scale to 1080i 60Hz(default 1080i of the player) the image size horizontally shrinks and shifts drastically to the left.
But when I use the NON default 1080i 50Hz the picture is perfectly sized and centered, trouble is though, the DVD player resets to1080i 60Hz once the player is turned off and on again.
Any one out there experiened the same thing before?
Any Input would be welcomed
Cheers
Ile
| Posted: Tue Sep 08, 2009 11:16 am Post subject: |
With crt projector you need to adjust different picture geometry and convergence for every resolution/refresh rate. Different refresh rates have different picture timings in your player.
Try to find way to chance default settings to 50Hz in your player, if you mainly watch PAL dvd's.
