BarcoData 808 - glow at the bottom of the tubes
gholt
Posted: Wed Sep 02, 2009 3:37 pm    Post subject: BarcoData 808 - glow at the bottom of the tubes
I have recently replaced all 3 tubes on my BarcoData 808, and everything is working. Great! But I've noticed that each of the tubes glows at the bottom whether or not an image is displayed. The brightness and contrast don't seem to affect it.
I'm still some what of a novice, and so I've purchased Graham Johnson's video, and perhaps that will help me diagnose issues like this in the future. But can anyone help me figure this out? I use this projector in a planetarium, so even beyond the possible burn-in issue, it casts a faint glow onto the screen/dome.
I've attached a photo of the green tube, in case that helps. All 3 tubes have the same glow, at the same brightness.
Thanks in advance for any help you can provide.
 Filesize:  14.81 KB
 Viewed:  7893 Time(s)
Ile
Posted: Wed Sep 02, 2009 5:37 pm    Post subject:
Chance resolution from your source to see if it helps.
It could be that your current resolution have so short vertical porch settings that ABL system don't have enough time for ABL pulse during vertical retrace and part off it is showed in tubes.
Other option would be turning ABL off and adjust G2 levels by eye.
gholt
Posted: Wed Sep 02, 2009 7:02 pm    Post subject:
Thank you.
I changed the resolution, and the glow pattern changed, but didn't go away. I also tried changing to another source. I switched to port 2, where I have a DVD player connected, and the glow was still there, but it had a darker area in the middle of the glow, instead of a relatively uniform glow along the bottom.
This may be a stupid question, but what is ABL, and how do I turn it off? I do know about the G2 pots. I've adjusted them on my Barco 800s. I can't find ABL in the manuals.
As a side note, does anyone know the max resolution on port 3? For some reason, I was thinking it was 800x600.
Posted: Wed Sep 02, 2009 7:25 pm    Post subject:
Pull the lenses off, put electrical tape right on the tube faces. Put lens back on. Done.
akajester
Posted: Wed Sep 02, 2009 8:30 pm    Post subject:
Your pj is same specs as my bg808. I've run higher than 720p without problems over port 3 but settled on 720p as it seems to be the sweet spot. I can faintly see the scan lines up close.
Posted: Thu Sep 03, 2009 4:18 am    Post subject:
Aurora Barcoalis Very Happy
Posted: Thu Sep 03, 2009 5:59 am    Post subject:
God, if that was a NEC I'd say the deflection had failed and it was about to destroy the tube..
But I have seen that on my Barco. Lile Ile said, I think it's the AKB/ABL line, but don't understand the details on this system on a Barco...so somebody explain it will ya???
damien55
Posted: Thu Sep 03, 2009 9:02 am    Post subject:
I have the same problem on my BG808. Someone suggested retrace lines but I'm not sure about that. It might well be this ABL pulse Ile is talking about.
I opened a discussion about the same problem in jan 2009 : https://www.curtpalme.com/forum_archived/viewtopic.php@t=14398.html . In my case the line actually ended up being on the tube face
You will notice that this line appears because we are in a widescreen format and that it should never be visible in a 4/3 configuration. If you want to move it a bit further outside the tube I think that adding some porch lines will move the picture down then if you move the raster up to compensate I think that this "ABL" line (or whatever it is) will move towards the outside of the tube face.
The other option is to move the screen up a bit to then have to move the raster up but that's not a very nice solution.
Damien
Ile
Posted: Thu Sep 03, 2009 11:09 am    Post subject:
Curts method is effective and doesn't cause harm to tubes.
Systems basic idea is to keep cathode current constant just above black level (185V), tubes and components wear out etc.
When ABL is turned on from vertical deflection board switch, it generates ABL pulse during vertical flyback. Vertical blanking need to be disabled during ABL pulse, so pulse can pass to cathode and can be measured and compared to reference voltage at rgb output amps. Then black level is adjusted if needed. ABL leds in rgb amps are also connected to this circuit and those are adjusted to turn of when black level is 185V.
Generation of ABL pulse can be turned off from vertical deflection board switch. Then also G2 levels should be adjusted by eye like in older sets like 800.
-select 6500K from color balance menu
-project test picture with video black bar.
-adjust brightness to 50 and contrast to 0
-adjust G2 pots until video black bar is barely visible at tube face.
More detailed description and schemas about ABL circuitry in 801s/808 can be found from 801s service manual, K and H sections.
http://www.curtpalme.com/docs/BarcoData801s_Service.zip (Size about 100Mb)
gholt
Posted: Thu Sep 03, 2009 5:23 pm    Post subject:
Crap! I just made things much worse!
Thanks to all of you that have provided information and advice.
Yesterday, I tried Curt's trick of applying the electrical tape to each CRT face, and that produced only marginal improvements. So today, I was STUPIDLY trying to adjust the G2 levels with a metal screwdriver, and dropped it! Grrr! So, after a couple of spectacular sparks I was able to unplug the projector and retrieve the screwdriver. So now, not only is the separate convergence power supply LED out, something else must be out as well, because I'm not getting any picture at all on any of the tubes. When I power up the pj, I can see the usual glow in the socket of each tube, but no glow at all in the CRT face.
So, where do I go from here? If necessary, I have an 801s that I can swap parts for, but that will also be my backup pj while I'm going back to the drawing board on this 808, so I don't want to do any swapping for anything other than diagnostic purposes. I also have an extra 800 that I can use for parts if that will work.
Thanks in advance for your help. Sorry for making this worse and wasting the time you had already invested in helping me with the refinements.
RobertMfromLI
Posted: Sun Sep 06, 2009 4:39 pm    Post subject:
Never metal screwdriver for those tasks. Absolute worst case (cannot get a proper plastic one) scenario, cut down a plastic putty/spackle knife to become a screwdriver and use that. I know it's too late to save the damage already done, but hopefully it will help in preventing a recurrence.
Kirk's 5 Year Mission continues at Star Trek New Voyages: Phase 2
Posted: Sun Sep 06, 2009 5:44 pm    Post subject:
Could just be a blown fuse on the SMPS. Or you need to send the G2 board to Curt to fix...
gholt
Posted: Wed Sep 09, 2009 6:37 pm    Post subject:
Robert, thanks for the tip, but I don't have an excuse, I had a plastic screwdriver. I just wasn't thinking.
Tom, thanks. I'm purchasing a couple of boards from Curt to try. Hopefully that will get me back on track.
Posted: Wed Sep 09, 2009 6:43 pm    Post subject:
+1 Thumbs Up
PaulB
Posted: Wed Sep 09, 2009 7:14 pm    Post subject:
Ha, I've seen the old Northern Lights a few times but believe it or not, what you see on the tube is exactly the way I saw them one night up in Shetland (group of Islands way north of UK mainland) - it was spectacular to say the least.
Maybe its God's way of saying that the Earth's G2 settings are out of whack Shocked
Paul
gholt
Posted: Wed Sep 09, 2009 7:34 pm    Post subject:
Yes, I did think the "Aurora Barcoalis" was pretty clever.
And I have also seen the last part of an auroral display look very similar. Believe it or not, it's all about electric charges and magnets!
Thanks again to all who are offering their wit and advice. I'll let you know what I figure out when the boards arrive.
Posted: Wed Sep 09, 2009 11:30 pm    Post subject:
Man, I'd hate to see the screwdriver you'd need to adjust THAT pot! Surprised
roland@b4
Posted: Thu Sep 10, 2009 3:30 pm    Post subject:
It did stop the tubes glowing which was the original problem Wink
