jetty
| Posted: Sun Aug 30, 2009 12:02 am Post subject: signal entry problem? |
I have my blu ray > hdmi > hdfury2 > rgb hooked up. I go into signal entry (after deleting what's in there) and create a new entry in the first position. The player worked fine. If I cut the projector off and start it back up either nothing shows up or just the red gun works. I've gone back and deleted the entry several times and sometimes the picture shows and sometimes just the red gun.
| Posted: Sun Aug 30, 2009 12:40 am Post subject: |
A make and model would help...
jetty
| Posted: Sun Aug 30, 2009 1:32 am Post subject: |
ooops .....runco 980 ultra
and actually it's my toshiba hd-a2 hooked up right now
| Posted: Sun Aug 30, 2009 1:50 am Post subject: |
Do you have the HDfury2's power supply and is the side switch on the HDFury2 set to RGB?
jetty
| Posted: Sun Aug 30, 2009 2:14 am Post subject: |
Yeah, it's set to rgb and I have the power supply on. I've seen it throw a pic, but when I turn it off and back on that's when things go wonky.
| Posted: Sun Aug 30, 2009 2:22 am Post subject: |
It is possible that the white balance is off, and a new signal entry is affecting that. Turn the AKB to the other position in the menu setting and see if that helps.
jetty
| Posted: Sun Aug 30, 2009 3:30 am Post subject: |
I turned on the machine and set it to the #1 input and only the red gun was working. I set the AKB to the ON position and all 3 guns had some kind of activity (a solid line along the bottom of the raster), but were still not working.
I'll mess with it tomorrow again. Might try the blu ray plyer next.
