Sony D50 - Blue is very green
drice1234
Posted: Fri Aug 28, 2009 2:47 pm    Post subject: Sony D50 - Blue is very green
I just swapped D50 projectors and on the new one the things that should be blue like the DishTV channel guide is displaying more as a aquamarine green. I am using an HDFury2 and RGB outputs so there is no color or hue adjustments available. Are there any pot adjustments to help with this?
Dan
damien55
Posted: Sun Aug 30, 2009 11:05 am    Post subject:
I had the same problem with my Barco 808 when I bought it. The problem was that "green in blue" switch was on the input board. This option was manly used in Graphics applications to make blue text and graphics easy to read. Human eyes are quite bad at reading blue texts. The problem then is that the color balance then completely wrong.
I don't know if your sony has such an option hidden in a menu or on one of the board but that's something I would investigate if I was you.
Damien
