Can someone point me to the right place to find out...
letre
Posted: Tue Aug 25, 2009 6:45 pm    Post subject: Can someone point me to the right place to find out...
I am new at crt projection but i have learned that curtpalme's website is comprehensive and contains most and answer to most questions. Then, can someone point to me where i could find an article that shows how to reverse the image. My projector is sitting on the table but soon i am going to bolt it upside down from the ceiling. How can i reverse the image?
CRT_Ben
Posted: Tue Aug 25, 2009 6:51 pm    Post subject: Re: Can someone point me to the right place to find out...
Welcome!
We could tell you if we knew what projector you had...but until then, check out this page: http://www.curtpalme.com/TechTips.shtm
Ben851
Posted: Tue Aug 25, 2009 6:52 pm    Post subject:
What's the make/model of the projector as it will be different for each model...
http://curtpalme.com/TechTips.shtm
See if you can find your model in the section on the left there - the manual should have the information you need!
Ben
Ben
CRT_Ben
I see the Bens think alike Wink
Posted: Tue Aug 25, 2009 6:54 pm    Post subject:
I can add a lot to this thread.
What make and model of set do you have? Very Happy
letre
Posted: Wed Aug 26, 2009 4:09 am    Post subject:
oops exactly what was I thinking when i posted that? My apologies. The projector is an Electrohome Marquee 8500. Also the synch lights keeps giving me an error and apparently i need to resit the hdm card. Whats the quickest way (minimal disassembly) to remove, clean and reseat this card?
dturco
Posted: Wed Aug 26, 2009 1:31 pm    Post subject:
Hello here is how to reverse scan in your Marquee.
http://etechvideo.com/techtip3.htm
The HDM is easy ceiling mount projector, open cage top, tap the side of the cage. The HDM card will crash to the floor. Of course this will cause some damage so ,Try this instead.
http://www.curtpalme.com/Marquee_Teardown4.shtm
But are you sure you need to? Post a few more times about specifics before tearing into your machine.
Even if your very careful if you play around long enough you can cause your self grief. Wink
I Know all about this. Embarassed { Causing grief that is} Sad
http://curtpalme.com/forum/viewtopic.php?t=17513
http://www.hulu.com/firefly
letre
Posted: Wed Aug 26, 2009 4:41 pm    Post subject:
dturco Thanks for the response. Your answer was quite adequate. Am sorry about your drop. It is not easy moving these things around, and specially when you do it yourself. I understand grief, a bit like getting ready to watch a movie and the sync red light comes on, %*#!
thanks
Eventually i would like to purchase a 9500 lc ultra. or even a barco reality 909. But i feel that the 9500 is more abundant and parts are easier to come by. an the actual difference is minimal.
Posted: Wed Aug 26, 2009 6:59 pm    Post subject:
On a proper screen, with good tubes, and good running condition an 8500 will throw a stunning picture. I had a visitor from Florida recently who told me "If I can my 9500 looking as good as this I will be very happy" He was looking at my 8500 with MP and HD mods on a 52 "x 92" Draper M1300 screen.
Don't get stuck on 8 inch or 9 inch, there's plenty of other little details that can make or break the picture quality.
