Conect OTA to CRT
Jester
Posted: Mon Aug 17, 2009 10:39 pm    Post subject: Conect OTA to CRT
HI!
I have what is probably a stupid question, how do I connect an antenna cable ( hd digital) to a CRT sony 1272 WITHOUT a cable box and get HD ?
Seems simple enough yet I cant seem to get my mind around it.
Posted: Mon Aug 17, 2009 10:45 pm    Post subject:
Hello
The cable signal, the one channel out of many that you want to watch, needs to be selected by a tuner or cable box or satellite receiver; these are not capabilities found built into commercial projectors. With the switch to all-digital tv transmission, no crt can do what you ask.
jkruger
Posted: Mon Aug 17, 2009 11:18 pm    Post subject:
You can find used Digital OTA/cable boxes that will do what you want. All you need to do is set up the antenna choice in the box to receive OTA signals and then hook it all up. You will need to find out which antenna and direction suits your location best. I use a standard tv antenna and it works great. The box I am using is the Samsung T-165.
Here's one:
http://cgi.ebay.com/Samsung-SIR-T165-HD-TV-Tuner-Receiver-High-End_W0QQitemZ290338890720QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item43998be3e0&_trksid=p3286.c0.m14
Jester
Posted: Mon Aug 17, 2009 11:23 pm    Post subject:
I have an antenna. Its wired and everything Smile I am ditching cable so now I want to use that antenna. I also use a HTPC so a tuner card may fit the bill.
If not the HTPC is there a OTS digital tuner that will output 720 p over hdmi?
jkruger
Posted: Mon Aug 17, 2009 11:29 pm    Post subject:
The sir-t165 does HDMI but the ts160 does not. it has dvi outputs
Posted: Tue Aug 18, 2009 3:58 pm    Post subject:
One of these with an HDFury1 works well for CRT:
http://www.amazon.com/Samsung-DTBH260F-HDTV-Terrestrial-Receiver/dp/B000JV6TQY/ref=sr_1_1?ie=UTF8&qid=1250611012&sr=8-1
I have a PHD-205 with a VGA output. It's pretty good too. A bit too much overscan though.
blue_z
Posted: Tue Aug 18, 2009 7:10 pm    Post subject:
Jester wrote:
I have an antenna. Its wired and everything Smile I am ditching cable so now I want to use that antenna. I also use a HTPC so a tuner card may fit the bill. ?
Hi there
I use an ATSC tuner in the HTPC to deliver HD content to my PJ, and think that is the easiest path. Also you get recording and time-shift capability as a bonus.
Your TV reception may dictate how good a tuner you'll need. Even though I'm 36 miles from the transmitters and the antenna is in the attic, there is still a good, clean TV signal. So every PCI or USB tuner I've tried has worked well for me. Even a $10 tuner (after rebate) (Kworld ATSC-120) works okay (but took a bit of tweaking).
For software, watchhdtv is free and requires minimal resources (compared to other programs). (Of course your video card and/or CPU needs to be able to process the MPEG stream for output to the PJ). If your HTPC is already Vista based, then upgrading to Win 7 is a possibility. The Win 7 Media Center is rather complete, and easy to install and use (the Kworld 120 installed under Win7 without any problems, unlike under WinXP).
Regards
AFryia
Posted: Tue Aug 18, 2009 10:36 pm    Post subject:
Viewsonic HD12 OTA tuner here, running YrPbPr component to the PJ.
It has DVI out but that's reserved for the HTPC which also has an OTA HD tuner and a cable tuner.
Jester
Posted: Tue Aug 18, 2009 11:42 pm    Post subject:
Sooo it seems the HTPC tuner is the option for me. Thanks for all the reply's and the help you guys are always a font of knowledge.
Jester
Scott
