barco remote help
studio
Posted: Mon Aug 17, 2009 12:45 am    Post subject: barco remote help
Have a 1209s with internal remote which works fine. I also have a R791664 wireless remote that doen't work with the pj. Are there any reasons why it doesn't work with the pj? The red led flashes when a key is pressed? New battery. Tried a cord with the remote with no success.
Studio
Decibel
Posted: Mon Aug 17, 2009 12:54 am    Post subject: Re: barco remote help
When you change battery must to set projector address in remote control.
With fixed control go to "Identification screen" and read your "projector address" (usually '0').
Press with a pen the square hole in the remote control (under ADJ key) then press projector address.
Domenico (Barco fan!)
secstate
Posted: Mon Aug 17, 2009 1:24 am    Post subject:
When was your Barco made? Some time in the Spring of 2000 they cut over to a newer remote with different codes. If the remote is not original to the projector then this might be the problem IF your projector is made some time in 2000 or after.
Posted: Mon Aug 17, 2009 1:47 am    Post subject:
Q: My Barco remote has stopped working, what has happened?
A: If it happened after you changed the battery (or removed the battery), the remote needs to be set-up to control the projector. The Barco remotes can control multiple projectors in a chain using addresses. The projector can be set to respond to a certain address only, using the dip switch's on the controller, what has been set does not matter as all projectors will respond to address 000. On the remote between the Adjust and Standby buttons is a recessed button you can press with a pen, press it and then press the 0 digit on the remote. The remote is now set to projector address 000 and the projector will now respond regardless to the actual address its set to. Alternately you can press the recessed button on the remote while aimed at the projector or screen and the projector will display its address (or bring up the Barco information screen from the menu to view the address), then proceed by pressing those numbers in sequence on the remote i.e. if the projector displays address 025 press 0 then 2 then 5 on the remote and it will be set to control a projector with that address, either way the remote will work again.
studio
Posted: Mon Aug 17, 2009 2:30 am    Post subject:
Hey Thanks All
Pressing the square hole and setting to 0 fixed it.
Studio
