resistor identification question
Posted: Fri Aug 14, 2009 9:59 am    Post subject: resistor identification question
I've been running into these quite a bit lately. They are blue in color and list their value right on the body. The question is, what does the letter that follows the value mean? For instance, the two over heated ones I'm looking at are 39K followed by what looks like a J. They are about 1/2 inch long and about 1/8th dia.
Posted: Fri Aug 14, 2009 10:36 am    Post subject:
I think those are metal oxide resistors but not 100% sure.
RogueChili
Posted: Fri Aug 14, 2009 11:45 am    Post subject:
the letter defines the tolerance; J = +- 5%
Posted: Fri Aug 14, 2009 1:24 pm    Post subject:
Are these the ones Chip ?
http://www.ttiinc.com/object/FP_KOAMOResistors.html
Posted: Fri Aug 14, 2009 1:26 pm    Post subject:
Yeah the marquee LVPS has those in there
Posted: Sat Aug 15, 2009 1:43 pm    Post subject:
Yep, those are the ones. They do test OK.
Now, same device different component to test. It's a diode with a funky number 2EZ5.1 Quick search comes up empty.
I'm still looking so I can test it. The control it came from is a Amtrol Boiler-mate smart control. Essentially a digital thermostat. They all seem to fail with the same symptoms and that is power related.
Posted: Sat Aug 15, 2009 2:06 pm    Post subject:
Thats a 5.1 volt zener.
Posted: Sat Aug 15, 2009 2:56 pm    Post subject:
I figured that was what it was with the "Z" in the part number. How do I test it.
Posted: Sat Aug 15, 2009 5:19 pm    Post subject:
DMM on diode test. Should show some resistance in one direction and no flow in the other direction.
