Haali tearing playing H.264 BD
barcoed
Posted: Thu Aug 13, 2009 11:15 am    Post subject: Haali tearing playing H.264 BD
Folks,
I’ve been playing MPEG-2 BD discs with KMPlayer / AnyDVD-HD / Reclock and Haali with very smooth results. Yesterday I played an H.264 on the same setup (dual core 2.8 / XP Quadro FX 3400) and noticed that the % processor used had jumped from the (MPEG-2 BD) average of ~33% to ~80% and that on big pans the picture was tearing and juddering quite noticeably. Change the video rendered to something a bit more basic (RGB surface) and the tearing goes away (but the picture isn’t quite as good and a little bit jerkier).
What gives?
greg_mitch
Posted: Thu Aug 13, 2009 1:14 pm    Post subject:
Does that vid card offer HW acceleration? Most likely a driver issue. Try a different player?
barcoed
Posted: Thu Aug 13, 2009 1:40 pm    Post subject:
The Vid card is supposed to be a bit of a beast and works beautifully for all DVD and MPEG-2 BD.
I'm running the latest everything including the XP patches and NVidia drivers (and Powerstrip).
MPC-HC is even worse - unwatchable.
I wonder if I will need a slightly more modern vid card with H.264 specific hardware decoding - and then will the players / filters / some other bit of software required, recognise / use this extra hardware?
Nothing's ever simple is it? Smile
akajester
Posted: Thu Aug 13, 2009 3:56 pm    Post subject:
I use a group of codecs specifically made for MediaPortal but uses MPC-HC as it's base player. It's called SAF (stand alone filters) and can be found here. The first page has all the directions to install and configure it.
Anyways, I use the latest version of haali with mpc-hc. I have an ati 4350 and catalyst 9.7 drivers and experience none of those problems! Have you checked what other codecs you have installed? Perhaps something is loading that shouldn't. For instance if you load the video in MPC-HC and run graphstudio you can see exactly how the video is rendering. If you have anything other than the codec and video renderer in the video path dxva will die. For instance subtitle loading will kill your dxva. You can disable the auto loading of subs in haali config or in directvobsub if it's installed.
Just a few pointers. Again, that first page of the SAF thread will teach you a few ways to troubleshoot these types of problems.
From the sounds of it, dxva stopped working which would cause the cpu jump. what video card is it specifically and does it support dxva?
-akajester
barcoed
Posted: Fri Aug 14, 2009 1:49 pm    Post subject:
Thanks for that but I don’t fancy installing MediaPortal (which appears to be a prereq).
In an act of desperation I changed from the Haali rendered to EVR (thought I'd tried that already but maybe not) and I have super smooth playback! No tearing, no judder – all fine. The processor is up there in the high 80s but the picture is fab! Cool
However, as is the way of things, I now have to alter gamma between DVD / BDMpeg2 and BDH.264 as they vary in apparent brighness (which they didn’t with Haali).
Ho hum. Confused
akajester
Posted: Fri Aug 14, 2009 4:43 pm    Post subject:
Actually you can extract the files from SAF and manually register them using regsvr32 from the command line. That way you get all the codecs you need, register them manually and use mpc-hc for playback. I've heard good things about the EVR renderer, i'd just rather not complicate an htpc with vista, so I'm running xp yet.
barcoed
Posted: Fri Aug 14, 2009 4:58 pm    Post subject:
akajester wrote:
~snip~... I've heard good things about the EVR renderer, i'd just rather not complicate an htpc with vista, so I'm running xp yet.
Me too. I'm running XP by choice despite being M$ certified in both Vista and Server 2008. The EVR does work better than Haali on my XP at least. Razz
Posted: Sun Aug 16, 2009 1:16 pm    Post subject:
Use madVR instead of Haali renderer. Perfectly smooth with Reclock (unlike Haali), and no tearing (if your graphics card is up to it).
But you will have to ditch KMPlayer for Zoom Player or MPC-HC.
huggy
Posted: Mon Aug 17, 2009 9:41 am    Post subject:
Mark is right, Madvr undoubtedly has the smoothest playback.This was evident on the opening scene of Apocalypto,with EVR playback was smooth however,you could notice the slight jerkiness on the very slow pan.Madvr however,was absolutely beautiful to watch,perfectly smooth panning and flawless playback.
barcoed
Posted: Mon Aug 17, 2009 10:35 am    Post subject:
OK - I'll check it out with MPC-HC.
Should I use the Beliyaal build or is that in the main version now?
Ta.
BobbyBlaze
Posted: Wed Aug 19, 2009 9:14 pm    Post subject:
How do you set up MADVR for smooth playback? It's like a bloody slideshow on my machine (q6600 oc'd, ATI 3870). Can someone share with me what boxes need to be ticked because I LOVE the IQ on MADVR. It looks amazing but I've never been able to get it to run smoothly. Really appreciate some assistance here.
Cheers,
Rob
Posted: Fri Aug 21, 2009 10:50 pm    Post subject:
I dunno.
I have a Q6600 at 3.0ghz and an Ati 2600XT, with MadVR at stock settings (except for levels) I get smooth playback of all material, bluray MKVs included. And I'm running it on a secondary monitor.
BobbyBlaze
Posted: Sat Aug 22, 2009 3:17 am    Post subject:
S'okay Dude, got it fixed now (but thanks for the reminder to have another crack at it). (had to disable RGB output in favour of YV12 in FFDShow for any other head scratchers out there).
WOW! I now realise that I've never seen SMOOTH playback b4 using madvr. Really, really impressed with it. Almost hypnotic. Shocked
Posted: Sat Aug 22, 2009 4:15 am    Post subject:
Ahh. With only RGB output enabled in ffdshow, you weren't using madVR. madVR only works with YV12.
BobbyBlaze
Posted: Sat Aug 22, 2009 12:10 pm    Post subject:
I had yv12 & rgb32 enabled. I was using Madvr (could tell by the renderer list and the picture quality. It has a different look to Haali) but it was about 1 fps. By disabling rgb32 as an output option it starting running up to spec (and jolly good she looks too).
