Cooling tube broken
Stryder
Posted: Tue Aug 11, 2009 9:49 am    Post subject: Cooling tube broken
Bad moment while lifting barco cine 6 up to ceiling mounts slipped and put a small hole in cooling tube . It leaked a little cooling fluid untill sealed, about 10 to 15 mil . What should i do ? : Embarassed
studio
Posted: Tue Aug 11, 2009 10:48 am    Post subject:
I just finished cutting my bellows lose and rotating the frame 90° and the best thing I found was some polyurethane epoxy. I bought it at McMaster Carr. It's flexible and bonds great to the rubber. On the package it says Double/Bubble Urethane made by Royal Adhesives & Sealants, LLc Belleville, NJ 07109 973-751-3000 website www.hardmanadhesives.com
Ile
Posted: Tue Aug 11, 2009 12:03 pm    Post subject:
Is there glycol leaks over boards? Glycol will cause shorts in boards...
If there isn't that big bubble in tube that cause reflections to screen, it doesn't matter.
If bubble cause reflection that can be seen in screen, you can remove convection tube from top and push bellows to fill that small air bubble and connect convection tube same time.
Stryder
Posted: Tue Aug 11, 2009 7:05 pm    Post subject:
Thanks for the respones . There was no leaking over the boards. So will mount back up tonight and turn back on and check . Thumbs Up
