Best sound card for HT under $100?
Posted: Mon Aug 10, 2009 3:32 pm    Post subject: Best sound card for HT under $100?
I've swapped some stuff around various computers for work / pleasure, and as such am currently stuck with onboard sound. It's got some odd problems that limit what I can do - horrible S/N at low output levels, for one. I like to have maximum volume be VERY loud, so that when I'm alone in the house with my buddies we can watch Transformers and shake the foundations. But I also need to have kinda normal levels for watching with my wife, and watching TV DVDs and things without lots of dynamic range.
I use the computer to control volume because I use separate amplifiers for each set of channels and the subs.
With the oldish SB I had in there, that wasn't a problem - I could have the computer output at 20%, all the amps turned way up, and I had to have my ear to the speakers to hear hiss. Then I just had to crank up the computer volume to really pound things.
With the onboard, though, setting output to 20% and turning things up enough to be at 'normal' volume results in hideous hissing and my hearing every hard drive byte transfer and video GPU operation. Not so good.
So - what's out there in a reasonably cheap HT-oriented soundcard? I'd like to stay away from Creative, just because they annoy the hell out of me.
I need (aside from the obvious good S/N etc):
Good quality analog outputs since I don't use HDMI / SPDIF
Vista support with solid drivers
I'd LIKE:
Nice software with good testing options (noise / tone output per-channel for testing, and I'd be in heaven if I could do per-channel pink/brown/white noise selectably)
7.1 support with analog outputs. At the moment I'm not set up for it speaker-wise, don't know if it makes sense in my space, and am not sure AC3filter can even DO it, but it'd be nice to have the potential
Any suggestions?
This seems well-regarded on newegg, and the price is right, but I figured I'd see if anyone had any input. Thanks!
Posted: Mon Aug 10, 2009 5:22 pm    Post subject:
The M-Audio Revolution 7.1 is a great card. It's long discontinued, but I'm sure you could find them used and M-Audio still seems to be supporting it.
I bought mine probably 5 years ago because A) they're a pro-sound products company, not a consumer junk company, B) they supported the Mac too, and C) good support and good software. I haven't used the analog outs in a long time, but when I did use them, they were very quiet. I still use the card in my HTPC, but with the SPDIF out.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250477764133
No idea how it compares to new stuff, but I know you like to save money when you can! Wink
Posted: Mon Aug 10, 2009 6:20 pm    Post subject:
Cool, ecrabb, I'll definitely check that out. The price is right, too, if it goes for what it's listed for now... Wink Do you know how good their software is?
Posted: Mon Aug 10, 2009 7:08 pm    Post subject:
It's been at least a year or so since I played with the software, so I can't remember what it's like. Pretty decent, IIRC. I can take some screen shots in an evening or two if you want.
Here's the manual if you want to look that over:
http://www.m-audio.com/images/global/manuals/Revo71-Manual-EN.pdf
Looks like excellent S/N specs on the analog outs - on paper, at least.
Posted: Mon Aug 10, 2009 7:14 pm    Post subject:
Here's an old review, but it might provide some additional insights:
http://www.techspot.com/reviews/hardware/revolution71
CRT_Ben
Posted: Mon Aug 10, 2009 7:45 pm    Post subject:
No experience with M-Audio multi-channel surround stuff, but they make good hardware at good prices. I have the 1010LT which I use for recording - 10 ins, 10 outs, all at once Mr. Green all for $199 Thumbs Up
akajester
Posted: Mon Aug 10, 2009 8:49 pm    Post subject:
I've always wanted to try an asus xonar. I just found it easier and cheaper to use spdif out and ignore the sound card processing altogether. the receivers do a better job than the sound cards do. I don't think that'll help for what you're doing though.
Posted: Tue Aug 11, 2009 2:42 pm    Post subject:
Nope, not with separate amps. Only other way would be a DTS preamp, and that'd cost more than my whole damn HT! Smile
And I'm just sending direct - I wouldn't think that the card is doing any processing if each channel is being fed individually by AC3filter. At least I'd hope not!
Posted: Mon Aug 17, 2009 9:58 pm    Post subject:
I have a Xonar HDAV Deluxe running analogue out.
And no, receivers do not do a better job, not if they are connected via spdif.
akajester
Posted: Tue Aug 18, 2009 2:11 am    Post subject:
Mark, can you explain this?
I've tried doing analog out with a prodigy card and it sounded very dull with my harman avr. that was with 6ch direct connects. Running over toslink sounds way better. My receiver is handling all the audio decoding. $200 sound cards do better?
Thanks!
Posted: Tue Aug 18, 2009 8:07 am    Post subject:
?The analogue inputs on your amp sucked?
?The prodigy sucked?
?You had the bass management wrong?
?How would I know?
But both my M-Audio Revolution 5.1 and my Xonar Deluxe sound at least as good as my Rotel Processor (RSP-985, once flagship), better when fed Hi res multi channel lossless sound.
Much as I hate The Eagles, I have a sample of the Hotel California DVD-Audio 6 channel track and it's amazing.
SPDIF is simply obsolete. A more interesting debate is HDMI versus Analogue.
akajester
Posted: Tue Aug 18, 2009 2:40 pm    Post subject:
This is the sound card I was using;
http://ixbtlabs.com/articles2/audiotrak-prodigy71/
Connected to a Harman AVR-330 via 6 or 8 channel analog in;
http://reviews.cnet.com/av-receivers/harman-kardon-avr-330/4507-6466_7-30632957.html
now that you know the equipment, any suggestions? I mostly used the spdif for the convenience, but did notice that it sounded cleaner. perhaps my analog cables were junk?
Thanks for your time! and sorry for the thread redirection. I figure some of us htpc'ers could learn from this. I'd like best possible audio quality out of my htpc.
-akajester
Posted: Wed Sep 16, 2009 2:53 pm    Post subject:
I'm seeing an M-Audio 1010LT on the bay for $100 buy it now. Pretty cheap... almost seems too good to be true given other prices ($100+ for used, $170+ new) supposedly new, from a seller with 169 100% + feedback. Accourding to M-Audio's web site, it supports 7.1 surround - and the pro features are pretty attractive given that I also do music production stuff and am hoping to set up a way to use the HT as a 'normal' office too.
Any reason I shouldn't jump on this?
Posted: Wed Sep 16, 2009 2:56 pm    Post subject:
Never mind... only has 4 pairs of analog outs. 7.1 is via digital, which won't work for me.
Damn.
