Barco 1208s/2 Issue
Z-Photo
Posted: Sun Aug 09, 2009 10:58 pm    Post subject: Barco 1208s/2 Issue
Silly me
The unit was working when i pulled it from the ceiling 5 months ago - no issues
We pulled the house from the market - so i get the HT back (was staged as a Bedroom)
Was set up as ceiling mount front projection
Now - Table mount Front projection -
Input
Port 5 input - RTC 2200 - cable
1080i/720p res
Units turns on
finds the correct source
projects an image -
Turns off after 1-2 mins
Tries to restart - the leds - all light up - it powers back down
I have turn it off by the power switch as it will not respond to the remote
after a few mins of being off - it will do the same thing
- I have not tried any other ports yet - i had always run port 5 or port 3 prior.
SO - any suggestions
thanks
Engineer by Day
Photographer by Night
My Portfolio
Posted: Sun Aug 09, 2009 11:21 pm    Post subject:
Laughing
Z-Photo
Posted: Sun Aug 09, 2009 11:35 pm    Post subject:
Yeah - I should have bought an AMPRO -
Engineer by Day
My Portfolio
Posted: Sun Aug 09, 2009 11:41 pm    Post subject:
Check the power button on the keypad (standby). If it's sticky, it could be intermittently connecting, and shutting the set off. Disconnect it and use the remote to make 100% sure.
Z-Photo
Posted: Mon Aug 10, 2009 12:41 am    Post subject:
Curt,
better - last longer -
Now when it shits off -
the third led on the computer is blinking -
The first and 5 th led (computer) are on
no others
it will not respond to remote
Engineer by Day
My Portfolio
Z-Photo
Posted: Mon Aug 10, 2009 12:43 am    Post subject:
When it is on - and projecting an image
The computer has
1 - 2 - 5 on solid
3 blinks
Engineer by Day
My Portfolio
Z-Photo
Posted: Mon Aug 10, 2009 12:54 am    Post subject:
It seems to be doing better -
Would this be an issue of caps that have complete gone away due to the storage (mini storage)
I will keep playing with it - and see if it gets better
Engineer by Day
My Portfolio
Z-Photo
Posted: Mon Aug 10, 2009 8:30 am    Post subject:
Unlike an AMPRO
The Barco seems to have fixed itself - (Hopefully)
I have had it on for 15 + mins. It had forgotten the memory settings - when it was shutting itself down - now it has the memory blocks and goes straight to the last setting -
I might have to mark this one up to a wierd storage electronic thingy (are you not glad that I am now in charge of developing the electronic control boxes for the T700 engines - lmao)
Engineer by Day
My Portfolio
Z-Photo
Posted: Mon Aug 10, 2009 9:04 am    Post subject:
Further info -
So i moved it slightly - to level it out with the wall - it went back to the cycling on/off -
I will pull the board and check them out again - sounds like some kind of loose connection/ board some place.
Engineer by Day
My Portfolio
huggy
Posted: Mon Aug 10, 2009 12:19 pm    Post subject:
A pinched wire maybe?
Z-Photo
Posted: Mon Aug 10, 2009 6:50 pm    Post subject:
Will work on it more when I get back to the house -
It does act like wire/short somewhere - maybe it is just pissed that i put it in storage.....
Engineer by Day
My Portfolio
Posted: Mon Aug 10, 2009 6:53 pm    Post subject:
That'll learn ya. Wink
THe fact that it was throwing an image means there's no problem in the actual set per se, I'd expect a pinched wire, maybe a bad convergence tray, a stuck remote button. A major error like a scan fail will shut the set down usually within 10 seconds or so. I have never had a bad cap shut the set down after it's throwing an image.
Posted: Mon Aug 10, 2009 9:51 pm    Post subject:
Has anyone noticed how really really nice I've been Mr. Green
Posted: Mon Aug 10, 2009 11:41 pm    Post subject:
My 808 was behaving strangely when we first fired it up.
It would run with the CPU tray closed, but not open. But all the connections looked fine.
After a while it came good (as did the red drive level - it started with high brightness, but low output).
I guess the caps just needed some volts through them to get them working reasonably well again.
Z-Photo
Posted: Tue Aug 11, 2009 1:36 pm    Post subject:
no
Engineer by Day
My Portfolio
Z-Photo
Posted: Wed Aug 12, 2009 12:20 am    Post subject:
Hey Curt-
Would a wonky wire going to the front camera cause any of this (?) - it has been the only wire found that has kinks in it.
It is currently up and running - that wire is disconnected ATM.
Spoke too soon - just cycled
I just swapped out the main power cord - (6 foot) to a different plug. Will see about that
Engineer by Day
My Portfolio
Z-Photo
Posted: Wed Aug 12, 2009 12:58 am    Post subject:
OK - went for 20 mins now.
Cycled - twice -
comp shows 1 - 5-6 solid led -
3 -blinks -
stopped cycling -
responded to remote to turn on
did not -
now 1-3-5-6 are solid
Engineer by Day
My Portfolio
Posted: Wed Aug 12, 2009 5:41 am    Post subject:
Z-Photo wrote:
no
I see a Barco in Chips future.....
Wink
zGman
Posted: Wed Aug 12, 2009 12:48 pm    Post subject:
Hi Pete,
Two things you could check (beyond reseating boards) would be the 110>220 jumper
plug on the power input board under the side cover (look for corrosion in the connector&pins),
and especially have a close look at the AC power connectors and jumpers to the main switch
down on the motherboard. These are a litle bit buried under fans etc, but I have seen
the wires/connectors fried/burnt, which could have been caused by corrosion or a bad crimp.
""I am now in charge of developing the electronic control boxes for the T700 engines"""
Tell us more.....!
G
Z-Photo
Posted: Thu Aug 13, 2009 3:20 pm    Post subject:
I did not see any obvious signs of corrosion -
but the PJ was on for a solid 2 hours last night.
So after i get the screen back up and a "new" green installed its football season.
Engineer by Day
My Portfolio
