Complete cold start of a P/J 9500 Marquee
dturco
Posted: Sun Aug 09, 2009 4:54 pm    Post subject: Complete cold start of a P/J 9500 Marquee
Let's say you want to install new tubes and magnetics like as in Install Sony Frankenyokes in your Marquee 9500. Shocked
If you were to do this how would you start reset the machine? You would have Zero point of reference. So what would be the very first thing you would have to do?
Obviously the machine is at the correct distance to the screen and square to the screen and all things have been installed properly. So skip that part.
This is how I think it should go, I am asking here not explaining, so If I am wrong that's to be expected, I am just trying to grab the theory here.
I have read Bill Blues guide and Guy Kuo's too. Something isn't clicking,or sinking in so...
1 Turn machine on.
2 Look for magic smoke, there is none.
3 Pull up help menu center rasters on the tube faces.
4 Put up full white screen and do all geometry to the green tube Color 2 and size, keystone,top&bottom,pin. ETC
5 The magnetics CPC, Now I am lost, as soon as I touch the magnetics I think I am moving the raster again so what is the reference point?
The guides say to neutralize the magnetics, but if the coils aren't in a place of center to begin with as you have had them off where and how is that done.?
I think I have a reasonable grasp after this point so I'll let the thread take us on that journey. Very Happy
http://www.hulu.com/firefly
tse
Posted: Sun Aug 09, 2009 5:11 pm    Post subject:
After any major change it might be helpful to unplug the CRT heaters at P14. Then if there is magic smoke there is less danger to the tubes. If things look good then plug in P14. The heaters will slowly come up to temp giving you a chance to pull P14 if something is wrong before the tubes begin full conduction.
I like to set up the magnets by first using the convergence position to center the pictures on the phosphor. Mark picture position on screen with sticky notes or masking tape. (Picture should be where you want it or projector physical position and/or mechanical set-up is off.) Press "0" on remote control to center position settings. Make magnet settings keeping picture on screen marks. When finished magnets are correct and position is correct without using convergence shift.
Null the magnets by overlapping the little tabs like the yellow ones in the pic. Remove all the sealing crap before you start.
Scott
 Filesize:  58.92 KB
 Viewed:  2973 Time(s)
Thomas Jefferson
Posted: Sun Aug 09, 2009 5:23 pm    Post subject:
Scott
Interesting idea, so let me see if I understand your method.
Center image on the tube face using the convergence controls,
then mark the position of the grids on the screen for each color? would that entail the edges and the center or just center?
then Press 0 while in convergence or when in all geometry functions?
now use the magnets to recenter all the grids to the screen tape markings?
then touch up with electronic controls?
Posted: Sun Aug 09, 2009 6:32 pm    Post subject:
Hello
Before pulling old tubes out, I advise setting G2s to 55, and Brite/Contrast to 40 so the new tubes come up softly. Make sure your G2 jumpers have a snug fit on the tube pins, and make sure you are connected on the right pins.
dturco
Posted: Sun Aug 09, 2009 6:54 pm    Post subject:
Thank you Scott and Tim. Thumbs Up
tse
Posted: Sun Aug 09, 2009 7:57 pm    Post subject:
Scott
Mark the edges of the picture on the screen. After they are marked press "0" while in convergence mode. One menu for green and one menu for red/blue. Loosen the three wingnuts on the focus magnets and move the focus magnet to place picture in marked place. Adjust neck magnets, move focus magnet to reposition picture. Repeat until flair is correct and picture is in correct place.
Scott
Thomas Jefferson
Posted: Sun Aug 09, 2009 8:08 pm    Post subject:
Scott
Scott
I never noticed you can zero out the blue and Red convergence? Now on the green i know if you hit Zero while in the green convergence service menu it clears it out, can this be done for all convergence while showing that color during regular convergence? So if in regular convergence and I am in the red color I can hit zero and it will clear the convergence for that color?
Posted: Mon Aug 10, 2009 12:28 am    Post subject:
Hello
Pushing 1 clears the static correction, 2 clears the zones, 0 does both and for red and blue. Clear green the same way in the service mode.
