250GTE
Joined: 24 Mar 2007 Posts: 21 Location: Washington State
| Posted: Fri Aug 07, 2009 4:24 pm Post subject: “Vidikron Vision 2” based on the Marquee 8110 vs 8500 |
I was looking at the “Electrohome Marquee Clone” list and see that the Vidikron Vision 2 was based on both the Marquee 8110 or 8500.
Does anyone know the date/year that the switch from being based on the 8110 to being based on the 8500 happened?
| Posted: Fri Aug 07, 2009 5:54 pm Post subject: |
Hello
That sounds like a mistake; Vision Twos were always 8500s; the Vision Three was an 8110.
250GTE
| Posted: Sat Aug 08, 2009 6:52 pm Post subject: |
Thanks for the reply Tim,
One more “Vision Two” question for the experts. It looks like there were several different cases that came on the Vision Two. I have a Vision 2 case on my 8500 AC and it is a 4 piece case (Front, Top/Sides, back input cover and the front power supply cover) but it looks like there is also a 6 piece case (link below). They look similar with the difference being that on the 6 piece case the sides and the top are separate pieces while the sides and top are one piece on the 4 piece case. Was one of these cases for the Vision 2 and one for the Vision 3 or did they change the case design at some point?
6 piece case
https://www.curtpalme.com/forum_archived/viewtopic.php@t=7106.html
| Posted: Sun Aug 09, 2009 5:43 pm Post subject: |
| 250GTE wrote: | Was one of these cases for the Vision 2 and one for the Vision 3 or did they change the case design at some point?
| most likely they simply changed the design. I had a 1997 V3 here with 6 piece case. The 8110 and 8500 are identical AFA physical dimensions are concerned. The V1 is also except for lens spacing, the bigger LC lenses are further apart.
