Moome Ext HD upgrade firmware ???
SweetChuck
Posted: Mon Aug 03, 2009 1:57 am    Post subject: Moome Ext HD upgrade firmware ???
A few years ago I was one of the first to buy a ext HD box , forget the model name but its black with the 5 bncs at the back 2 hdmi inputs and 1 YUV . Anyway it has a problem with the remote not working and sometimes locks up to one input and has to be powered down to switch inputs . I told moome about it and he sent me the components in the picture . However i was unable to get a procedure for the mod . there a few SM capacitors resistors and a Eprom of some sort . has anyone done this and has a procedure , or maybe moome can Chime in .
moome
Posted: Mon Aug 03, 2009 7:31 am    Post subject:
please send email request to moome@curtpalme.com or moome@seed.net.tw, we will send you the file~
ralpharch
Posted: Mon Aug 03, 2009 1:37 pm    Post subject:
Moome - I have that Ext-HD box as well (VGA out and DVI-test feature). In my case I sent it once to Barry to get the ringing fix done and then later sent it to you as the power supply wouldn't stay on at the jack
However I still have problems as described by OP regarding changing inputs and powering on/off with the remote. In my case it will sometimes work. Other times I may have to repeatedly hold the remote down for maybe 10 - 20 seconds and sometime along there it will change input (this can be after having it on another HDMI or component for a long time - or just after switching). As we all know it is responsive if you power it off and back on; so I have mine powered off the reciever's switched power.
Is there something that really fixes this or do I have the fix already (having had Barry repair it)?
moome
Posted: Mon Aug 03, 2009 3:57 pm    Post subject:
it will need to check when you send to barry for upgrade~
moome
Posted: Mon Aug 03, 2009 4:00 pm    Post subject: Re: Moome Ext HD upgrade firmware ???
Edge problem solution.pdf
files for upgrade EXT-HD
 Filename:  Edge problem solution.pdf
 Filesize:  1.8 MB
 Downloaded:  769 Time(s)
Posted: Mon Aug 03, 2009 4:04 pm    Post subject:
I have a simple solution to the locking/etc problems. I just plug my EXT-HD into my receiver's switched power outlet. That way the EXT-HD gets powered on every time I use my HT. I haven't had any troubles since I started doing this. On the other hand I usually only have one source so I don't switch inputs all that often, but I do sometimes switch and it has always worked OK since I started doing it this way.
SweetChuck
Posted: Mon Aug 03, 2009 11:34 pm    Post subject:
Sweet , Thanks Moome Thumbs Up
moome
Posted: Tue Aug 04, 2009 2:00 pm    Post subject:
it is my pleasure~
gary, it is a good way to solve the lock problem by power EXT on/off~~
benleeys
Posted: Mon Oct 05, 2009 6:50 pm    Post subject:
Hi moome,
Will you accept my EXT HD for upgrade before it develops any problem? I can ship it to you in Taiwan easily.
Ben
moome
Posted: Wed Oct 07, 2009 2:24 am    Post subject:
benleeys wrote:
Hi moome,
Ben
sure~ please email to moome@seed.net.tw and moome@curtpalme.com
