What causes crt's to pop?
RVonse
Posted: Tue Jul 14, 2009 10:37 pm    Post subject: What causes crt's to pop?
Specifically what I am talking about is the loud high voltage snap followed by no video for about 1 second. We've all experienced this at one time or another but lately it seems more frequent for me and I think it may very well have to do with a different red crt installed 6 months ago. Or perhaps the new quad I put in about the same time? I just don't know. But I do know that the red crt (panasonic 9"er) came from a guy in Florida who had it stored idle for a number of years.
For a while I even thought I was having a video fault on one of my cards. The picture would fade out but I knew there was still high voltage because the crts were still lit if you looked directly into them. Until then one day a large amount of popping took place which seemed to correct the video dropout issues I thought I had. On some occasions, I see a flash of all red raster but most of the time it is just one single pop, blackness, and then video coming faithfully back. Scares the crap out of me.
So my question is, is this something that some crt's tubes can do more than others and could it be high voltage arcing in the guns?
It hasn't really been a huge problem but I can't help but think there might be something to do in order to prevent a disaster in the making.
Posted: Tue Jul 14, 2009 11:00 pm    Post subject:
When you crack open a tube and see inside (they are basically empty apart from the electron gun assembly), you really do have to wonder.
My new P16 tubes did a couple of little pops, nothing major.
Posted: Tue Jul 14, 2009 11:22 pm    Post subject:
Its small pieces or dirt or contamination or phosphor that finds its way into the tube during the phosphor application phase. Tubes should be stored face down so none of those loose particles find their way to the Cathode,G2 or G1 grids. The pops are those contaminants getting fried by one of those components, some times tapping the tube neck after installation will shake these parts free and/or burn them off.
Posted: Tue Jul 14, 2009 11:49 pm    Post subject:
What I'm trying to say, is when you crack open a tube, you have to wonder where these mystery loose particles come from..
Posted: Wed Jul 15, 2009 3:06 am    Post subject:
I think some are also part of the Cathode that is burned of during use.
Posted: Wed Jul 15, 2009 2:38 pm    Post subject:
You guys are forgetting the fact that this could be caused by a HV arc anywhere in the HV path, not just in a tube. I didnt see where he posted that he saw the arc in the tube. So he would have to look for the arc to see where his problem is. It is not just inherent to a tube, even tho it could be. Smile
Rdean
Posted: Wed Jul 15, 2009 4:42 pm    Post subject:
Have you had the covers off and lights out and tried to see where arcing may occur? I had a similar problem. A pop followed by video going black then slowly coming back over a second or so.
Mine was arcing from the HV boot to the tabs on the deflection yoke. To fix I replaced the HV leads as in
http://www.curtpalme.com/HV_Lead_Removal.shtm
Age causes the boot's rubber to dry out and small cracks allow paths for the arcing.
Posted: Wed Jul 15, 2009 5:00 pm    Post subject:
Age and ozone. Have you ever tried to stretch on old rubber band and have it break. Ozone breaks down the chemical bonds in rubber.
http://scifun.chem.wisc.edu/CHEMWEEK/Ozone/ozone.html
Older Infinity speaker surrounds come to mind.....
Rolling Eyes
Cousin.It
Posted: Thu Jul 16, 2009 1:59 am    Post subject:
I had a projector a while back that sat for a while and when I got around to turning it on again it had a bunch of crackling pops it kept doing. I tracked it down to tiny spiders and little spider web strands in the tube bell area. I just cleaned that area out and fixed it.
Mark
dturco
Posted: Fri Jul 17, 2009 3:24 pm    Post subject:
What causes crt's to poop?= GOZER sauce Laughing
http://www.hulu.com/firefly
Posted: Fri Jul 17, 2009 4:15 pm    Post subject:
DAMMIT! You beat me to it! I've been meaning to pop into this thread for the last two days and make some reference to never hearing or seeing my CRTs "poop" a single time. What does CRT poop smell like, anyway? Fried electronics?
Posted: Fri Jul 17, 2009 5:20 pm    Post subject:
He he he he he....
~MOD
CRT_Ben
Posted: Fri Jul 17, 2009 5:30 pm    Post subject:
He he he he he....
~MOD
Don't think I didn't notice! The original thread title was "pop" and a few days ago it changed to "poop"! Razz
Now it's back to "pop" Smile
