Barco Data 808s - Which tubes are compatible ?
the_maniac
Posted: Fri Jul 10, 2009 8:50 am    Post subject: Barco Data 808s - Which tubes are compatible ?
Hello,
I've bought one Barco Data 808s form ebay austria for 100€.
But the Blue and Green tubes are very bad (Rating 4-6).
Which tubes are compatible to the BD808s ?
180DVB22, 180DMB22 but are there also others ?
greets
www.diy-community.de
Elaine Benes
Posted: Fri Jul 10, 2009 11:11 am    Post subject:
PT18-205 are higher resolution versions of the 180DVB's, they'll work.
secstate
Posted: Fri Jul 10, 2009 2:38 pm    Post subject:
p16lnq and p16lnp will also work and are also higher resolution tubes. Also remember the DMBs need to have a neckboard mod to work in Barcos.
Posted: Sat Jul 11, 2009 11:19 pm    Post subject:
I thought the 808S used the hard to find Sony tubes? If so then none of the Panasonic 180's will work.
Elaine Benes
Posted: Sat Jul 11, 2009 11:49 pm    Post subject:
Barco DATA 808s's often have Panasonic tubes in them, GRAPHICS usually have Sony tubes in them, but with Barco, there is no hard and fast rules like that. I have a GRAPHICS, a high resolution model, which has Panasonic tubes installed from the factory.
secstate
Posted: Sun Jul 12, 2009 2:39 pm    Post subject:
Also earlier Cine8s used Sony tubes as well. Later ones went back to MECs. You can put MECs into a Graphics 808s by getting the CRT mounting blocks (front hardware) for MEC tubes and either modding the necboards or getting the MEC neckboards. The problem is more finding the parts than any technical difficulty in swapping the parts.
the_maniac
Posted: Sun Jul 12, 2009 3:39 pm    Post subject:
ok thanks for the replies.
atm there is a set of 180DMB22 on ebay germany. i'm trying to get them.
does anybody know what exactly needs to be done to run the DMB's in the 808s ?
