barcoguy
| Posted: Mon Jul 06, 2009 8:05 pm Post subject: P19lug in 1208/2 |
Do the P19lug tubes have the same pinout as the 180dvb22 that come stock in the 1208/2 ? I know it will be a TON of work to physically fit these tubes in...
| Posted: Mon Jul 06, 2009 10:53 pm Post subject: |
Yes, they are the same... I think.
| Posted: Wed Jul 08, 2009 2:59 pm Post subject: |
Check this out http://www.cir-engineering.com/bin/P19%20pinouts.pdf.
barcoguy
| Posted: Wed Jul 08, 2009 8:03 pm Post subject: |
Ok thanks does anyone have a similar diagram of the 180dvb22 tubes? I just dont want to blow anything if we are not 100%
r.bauer
Joined: 08 Apr 2006 Posts: 280 Location: The Netherlands
| Posted: Thu Jul 09, 2009 6:15 pm Post subject: |
I have seen LUGS working perfectly in a BG1209/2, so a 1208/2 should not be a problem. Just look at the orientation of the socket if you have LUGS that come with a Barco housing.
The BG1208s and the BG1209s have the sockets rotated 180 degrees, but I don't know if that is also the cas with the BG1208/2 and the BG1209/2.
Blockbullie
Joined: 15 Apr 2010 Posts: 224 Location: willamette valley ,Oregon
| Posted: Sun Feb 09, 2014 2:43 pm Post subject: |
Boy a sigmatic of the 1208-2 sure would be nice and the 808 two maybe Thanks
_________________ Rich mans taste with a poor mans wallet
digitalayon
| Posted: Mon Feb 10, 2014 8:55 pm Post subject: |
I asked this question a few years ago on my then 1208s/2 I think it would work great. But everyone said there was no way to mount the tubes and lenses. bull****!!! I think something can be fab'd if someone was to make a solid works or cad drawing to send into Metal Mart.
Blockbullie
| Posted: Tue Feb 11, 2014 8:35 pm Post subject: 1208-2 swapping 8" with 9" p-lugs. |
Thanks A bunch, I try to Think things over twice ,before Kicking the juice to her. If I remember right the 1208-2 will not light up , unless all three tubes are plugged in .
for some reason I think I needed to put a resister on the neck cards.
Any way, any wisdom on this would be of great . Thanks guys
fragzero
| Posted: Tue Feb 11, 2014 8:44 pm Post subject: |
Pinout is the same, main issue is the fact that the socket is 180 degrees rotated.
Blockbullie
| Posted: Tue Feb 11, 2014 8:58 pm Post subject: |
I was looking for that , Your mind reading skill good, Thanks
180 out no problem , at all...
