Marquee 8000 side pin not working
db55047
Posted: Fri Jun 26, 2009 3:18 am    Post subject: Marquee 8000 side pin not working
May 1995 Marquee 8000 V2.0 software side pin has no effect 0 to 100. Any ideas/suggestions? All other adjustments seem to work normally.
Thanks, Don
Posted: Fri Jun 26, 2009 3:20 am    Post subject: Re: Marquee 8000 side pin not working
Thanks, Don
Clean all the chips on the CLM and the connectors to the DPB. pay attention to U7 on the DPB.
Also check the connection of the ribbon cables going to the CVA and VDM
Posted: Fri Jun 26, 2009 2:49 pm    Post subject:
Hello
Side pin and keystone are effected by modulating the raster width, so you may have an issue with the horizontal deflection board.
Hello
db55047
Posted: Fri Jun 26, 2009 3:25 pm    Post subject:
I'll take a look at the chips connectors and cables. Tim, keystone works fine just side pin is not working. I can work around it using converge on green but would rather fix the problem if possible.
Thanks for your replies, Don
