Help!1031qm convergence problem
filet
Posted: Sun Jun 21, 2009 6:07 pm    Post subject: Help!1031qm convergence problem
My 1031q have some problems on the DB board, all the convergence pot related to horizontal won't work but vertical can be adjust. All the fuse on the board were normal.
Please advise how to repair it. Other problem is my living place is in Hong Kong and may have difficulty get replacement parts, so please advice too!!
Thanks!
filet
Posted: Mon Jun 22, 2009 4:15 pm    Post subject:
should the DB board be replace?
Posted: Mon Jun 22, 2009 4:33 pm    Post subject:
If your saying you dont have any horz controls for any color then no, the DB is not a definite. The DA also comes into play plus possibly others. Testing would have to be done to verify or just board swaps until the right one is found..... Smile
filet
Posted: Mon Jun 22, 2009 4:40 pm    Post subject:
thks for reply.the problem is I how can I can't find parts in hong kong, so I need help from the forum to get the parts. any ideas?
Posted: Mon Jun 22, 2009 7:04 pm    Post subject:
I have whatever you need. I would probably change the convergence board first, as I have had your symptoms before, but as Macguyver says, it could be another board.
$50 plus shipping for a convergence board. Email me at curtpalme@shaw.ca if you want one. Shipping for that board will be about $25.
filet
Posted: Tue Jun 23, 2009 4:30 pm    Post subject:
thks for reply, this forum is really helpful.
I've send u email please check it! Wink
filet
Posted: Thu Jun 25, 2009 10:31 am    Post subject:
Hi Curt,
Did u recieved my email regarding the DB board ordering? pls reply asap!
filet
Posted: Sat Jul 18, 2009 6:01 pm    Post subject:
the red and blue horizontal convergence are fine, however, the green signal gone and red and blue signals are flickering after swap the DB board! so what may the probable cause? Crying or Very sad
remarks: the projector will shut down when it is not yet warm up and switch to hi-scan since I run it at 480p, but it will resume normal after warm up.
filet
Posted: Sun Jul 19, 2009 11:46 am    Post subject:
the internal test pattern is also perform as above 1st line described. Neutral anyone can help?
Posted: Sun Jul 19, 2009 3:39 pm    Post subject:
Be more specific with what your saying here....... Smile
Whats different since the board change, whats working, whats not and so on.....
filet
Posted: Sun Jul 19, 2009 5:30 pm    Post subject:
ok, before board swapping, only horizontal convergence pots won't work, after swap it, convergence pots work but no signal produce from green tube and red and blue tubes were produce flickering signal as interlace scan. swap back old board but problem still. any ideas?
Posted: Sun Jul 19, 2009 5:44 pm    Post subject:
So now even when you put in the old board you dont have green and the red and blue flicker?
Posted: Sun Jul 19, 2009 6:02 pm    Post subject:
I ran the board for a few hours before sending it, and checked all functions. Are you sure that the CRT on/off switches are simply not turned off? You may have multiple problems in the set..
filet
Posted: Mon Jul 20, 2009 1:37 pm    Post subject:
I think your board is fine. before the convergence problem, the projector is always shut down with hi scan mode(480p) when cool fire up, few times fire up again it will work fine (problem exist since 2003).
last month when I hook it up with new purchased BDP-05FD and the PIXEL MAGIC VPS2300, it shut down after first time fire up, and then second fire up the convergence control gone. after DB board swapping, it shut down when first fire up, and then second fire up the green gone and red and blue were flickering.
to be continue..............
Posted: Thu Sep 17, 2009 6:59 am    Post subject:
I had a very simular issue with my VPH 1001 QM, the way i ended up getting it working was pull the removable chip out of the board underneath the convergence board, and re-seat it carefully. All my converenge was perfectly fine after that, all the pots worked exactly as they should.
