Zindar
| Posted: Fri Jun 12, 2009 2:46 am Post subject: I'm checking for HDfury compatibility |
Hello,
My employer was trying to get rid of an expensive CRT high definition 32 inch monitor, and nobody would buy it from them, so I gave them $25 and took it off their hands. It accepts VGA input, so I'm interested in purchasing a product from HDfury that will convert and HDMI output on my HD TiVo (DVR) to a VGA signal to go into my new monitor.
The monitor is made by Monivision, model DM-6952S.
I'm attempting to test what sort of resolution it can display. The specs say:
Compatibility: PC VGA, SVGA, XGA (640 x 480 @ 60, 72,k 75, 85 HZ / 800 x 600 @ 60, 72, 75Hz / 1024 x 768 @ 60HZ
Digital TV Format 480i, 480p, 1080i, 720p
So I'm guessing it can at least support 720p, which is one of the possible outputs my HD TiVo is capable of outputting.
I read on your site that to test this ability, I should attempt to send an image from a PC with 1280 x 720 resolution.
I did so, and compared to 1024 x 768, here's how the image looks.
1024 x 768 looks completely normal. 1280 x 720 looks pretty close to normal, but the images are skewed a little in the sense that things look kind of compressed in the horizontal dimension, but not the vertical. Maybe that makes sense, because it's trying to fit 1280 pixels, not 1024 in the same amount of horizontal space.
In addition, there's a slight curvature in the sense that things in the middle of the screen are compressed more than things in the top or bottom, kind of like a horse's saddle if you know what I mean.
In other words, when displaying a square on my screen it looks shaped more like a horse's saddle as seen from above where the narrow part is in the middle of the screen, and the wider parts are above and below.
It's not a pronounced effect, meaning the curvature is not great, but I can notice it.
Is this normal? Does this count as a successful or unsuccessful test of 720p?
Also, I did a screen snapshot of the skewed image, but when I display the screen snapshot on my other computer/monitor, it's not skewed at all. So the skewing is just how it looks on my new monitor. The data itself is not skewed.
| Posted: Fri Jun 12, 2009 6:14 am Post subject: |
The distortion you are seeing can be corrected most of the time in the service menu. The reason it's not showing up on the camera is due to the barrel distortion of the lens. It's canceling out the bow of your monitor.
You say at 1280x720 the picture looks compressed in the horizontal direction, it's more likely that it's stretched vertically. Again you could try to adjust this in the geometry menu. I believe that's a 16:10 monitor, when displaying 19:9 you should have some narow leterbox bars top and bottom on your screen.
Try 1080i, it'll be easier on the monitor. 33.75KHz vs 45KHz for 720p, plus it's 1920x1080 so you'll see more detail.
You may also need to get into the menu to correct for the left offset of the VGA signal that comes out of the HDFury1/2. This is caused by the short digital signal timings coming out of the Bluray/DVD/STB etc...
I would recommend a Box1040, this will give you component input and image alignment correction to help adjust the left offset. You can either go with the HDFury1 and plug it directly into the Monitor and try to adjust in the menu or add the Box1040 in there between the HDFury1 and the monitor and use the IAC circuit to center the picture going to the monitor.
The combo of the 2 should give you a good picture and DVI/HDCP as well as component input compatibility. The added bonus of gamma boost will bring out the shadow details in movies.
Your setup would be as follows:
STB----HDMI.to.DVI.cable---HDFury1|Box1040==VGA.cable====Monitor.
HDFury1 FAQ's
https://www.curtpalme.com/forum_archived/viewtopic.php@t=5282.html
Box1040 FAQ's:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10987.html
Zindar
| Posted: Fri Jun 12, 2009 3:09 pm Post subject: |
Thanks for your useful comments.
| AnalogRocks wrote: | | The distortion you are seeing can be corrected most of the time in the service menu. |
If you mean the menu built into the monitor, I checked that. It has options for moving the image left, right, up, or down, and also for changing the width or height of the image, but nothing for "debarrelling" the image.
| AnalogRocks wrote: | | Try 1080i, it'll be easier on the monitor. 33.75KHz vs 45KHz for 720p, plus it's 1920x1080 so you'll see more detail. | I just assumed because the specs of the monitor don't mention 1920 x 1080 resolution, it wouldn't support 1080p. I'm completely new to this technology, so I could be wrong. Somebody told me not to even attempt to send this kind of resolution to the monitor, as it maybe could damage it. Are you saying you think it supports it?
| AnalogRocks wrote: | | I would recommend a Box1040, this will give you component input and image alignment correction to help adjust the left offset. You can either go with the HDFury1 and plug it directly into the Monitor and try to adjust in the menu or add the Box1040 in there between the HDFury1 and the monitor and use the IAC circuit to center the picture going to the monitor. | Out of curiousity, would the Box 1040 also help me out with the barrel distortion?
| Posted: Fri Jun 12, 2009 3:34 pm Post subject: |
| Zindar wrote: | Thanks for your useful comments.
| AnalogRocks wrote: | | I would recommend a Box1040, this will give you component input and image alignment correction to help adjust the left offset. You can either go with the HDFury1 and plug it directly into the Monitor and try to adjust in the menu or add the Box1040 in there between the HDFury1 and the monitor and use the IAC circuit to center the picture going to the monitor. | Out of curiousity, would the Box 1040 also help me out with the barrel distortion? |
HI Zindar,
No the Box1040 won't help you with the barrel distortion. That has to be done inside the monitor. There may be a second hidden service menu on that monitor.
At to 1080p NO the monitor will only scan to 54KHz maximum, 1080p is 67.5KHz so no it won't do 1080p.
However 1080i is very do-able. The spec's do mention it. It said 1080i.
Both 1080i and 1080p are 1920x1080, the difference is in the frame rate. 1080i is 30 fps and 1080p is 60 fps. There's a little bit more to it than that but that's the basic jist.
Some monitors can be damaged by feeding them 1080p yes. Not sure if yours is one of them.
Jeremy
Zindar
| Posted: Sun Jul 05, 2009 4:48 am Post subject: |
By the way, I wanted to follow up. I ordered the HDfury, but not the box1040, because I wanted to first see how good a job the HDfury does without the box1040. There is no barrel distortion at all, so I'm very happy.
Also, the vast majority of my programming I get from my TiVo DVR is in SD quality, but I still see a significant improvement watching it on my 32" computer monitor / HD fury combo, compared to my decades old 27" SD TV, so overall I'm happy.
But I'm confused by what I'm seeing on my HD channels. I hooked up an antenna so I could pick up some local networks OTA in HD quality. (I did this because my Time Warner cable is delivering SD programming to my TiVO.) My antenna is hooked directly to my DVR, but it's an HD TiVo, which is equipped with a built in digital tuner, so it's able to tune into my local HD networks, through the antenna. (It has two inputs: one for cable and one for antenna, and it's able to simultaneously accept signals through both inputs.) So I tried looking at one of those channels, and then I flipped to the analog version, which I have available through my Time Warner analog cable. I kept toggling back and forth between the two versions, watching the same show so I could compare the quality.
I was expecting dramatically better quality through HD, because everybody raves about HD. But I could hardly see any difference in quality. And the scenes I was looking at were brightly lit scenes, and I thought my lack of a box1040 only hurts me on the darkly lit scenes, so I don't understand why my HD shows don't much better than the SD shows.
I admit I only tried this on one show. I'll try some more to see if this is a consistent problem.
| Posted: Sun Jul 05, 2009 5:11 am Post subject: |
What resolution did you have your output set to? Does your cable box actually output 1080i or does it just receive HD signals and downgrade them to SD?
Zindar
| Posted: Mon Jul 06, 2009 6:31 pm Post subject: |
| AnalogRocks wrote: | | What resolution did you have your output set to? Does your cable box actually output 1080i or does it just receive HD signals and downgrade them to SD? |
I did have it set to 1080i at one time, but I must have accidentally changed the settings. I've just changed it back to 1080i, and I can definitely see the difference in video quality now. (To clarify: I set it to 1080i Hybrid mode. This means my TiVo will use 1080i for HD programs, but a lower quality for SD programs... it can tell from the signal which kind of programs it's dealing with.)
Now my next problem is to try and find more HD channels. I have Time Warner cable analog supplying me with TV content, so with the except of one channel, all of that is in SD. So I thought I'd pick up some HD channels over the air. I first tried a really old rabbit ear antenna, and I picked up some channels, but they kept cutting out on me. So I then went to Walmart and bought a $9 antenna that's specifically marketed to pick up HD OTA channels. I can pick up only a few, but from where I live, I'm supposed to be able to pick up 8 of them, so the antenna is a little dissapointing. Also, I notice that if I don't point the antenna in a certain direction, I get pixellation.
The biggest problem is I'm getting zero signal strength for KXAN (our local NBC network), and this is the channel I most want. I'm having trouble figuring out where their tower is so that I can may understand why I'm not picking it up, but maybe if I invest in a more expensive antenna, I might pick it up.
On another note, my HD DVR has a nice feature where it accepts both cable and antenna input, so it can seamlessly records whatever lineup of shows I give it, even if some are in HD quality and some in SD.
Another possible solution I was trying to avoid, but I guess I should consider, is that Time Warner (who supplies my cable) will rent cable cards to me for a few dollars a month. My HD TiVo has a feature where I can install those cards, and even though my input is an analog cable, I'm told this cable contains the local networks in HD quality being transmitted through that cable, and if I install the cable cards into my TiVo, it will be able to access those HD locals through the cable card. The advantage is I get all the locals, and I don't have to worry about pointing my antenna in a certain direction. The disadvantage is there would be a monthly fee of a few dollars involved.
Zindar
| Posted: Mon Jul 06, 2009 6:38 pm Post subject: |
Update: On this website, I see a map showing the location of the KXAN tower. Just eyeballing the map, my brain roughly estimates the tower is 10 or 20 miles from my house. It's also in a hilly area of Austin, so I bet they put the tower on top of a tall hill. You'd think I should be able to pick it up.
Zindar
| Posted: Sun Jul 06, 2014 1:56 am Post subject: |
I just found this old thread of mine. Sorry, I see that my ramblings about tuning into HD channels was off topic from this thread, and I probably shouldn't have done that. I did eventually, years ago, solve all those old tuning problems. The solution was simply to put my antenna near a window, facing the direction of the towers.
