frusterated
bccole23
Posted: Tue Jun 02, 2009 5:55 am    Post subject: frusterated
i purchased the vim hd card for my marquee 9500 lc and i have tried asking moome on the return email and i have posted in his section with no response. can somone from this site help. the remote dos not work that it came with and it will not let me take any of my components to 1080p just 1080i
Posted: Tue Jun 02, 2009 6:51 am    Post subject:
First off what are your sources your feeding the Vim HD? I do not think any Component input can accept 1080p but i am not sure if any HTPC guys are doing it that way. I always thought 1080p was a HDMI only output and it would shut off 1080p through Component with the HDCP signal shutting it off from the source.
Also Moome is pretty good with taking care of problems:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=16448.html
Elaine Benes
Posted: Tue Jun 02, 2009 9:59 am    Post subject:
The remote sensor on the cards is VERY difficult to activate. It doesn't generally receive the signal very well, and you need to reset the remote often. It is a fairly well known shortfall in the card. Experiment with positioning the remote at various angles to the sensor and push the adjustment buttons infrequently, leave lots of time between button pushes while you are trying to find the angle that works with the sensor...
bccole23
Posted: Wed Jun 03, 2009 12:13 am    Post subject:
I am using hdmi 1.3a cable and it is going up to 1080i but does not want to go 1080p or even play the blue ray, i am using a play station three as he player and i hooked it up to my lcd and it play's fine so i can only guess it is somthing in the card or setting?
k.berger
Posted: Wed Jun 03, 2009 12:23 am    Post subject:
Make sure that the 1080p/24Hz playback is disabled in the PS3 settings. If it's ON, PS3 will default to it for movie playback, and of course no CRT will sync to it (and even if it could, it would be unwatchable, because of judder).
Kris
Posted: Wed Jun 03, 2009 6:22 am    Post subject:
K.Berger is right the PS3 needs to be set to 1080p@60 not 24.
