secstate
| Posted: Sun May 24, 2009 10:12 pm Post subject: Re: Barco 1209s LC Tanks |
| km987654 wrote: | | Is it possible to put Sony tubes in LC tanks of a Barco 1209s that did house MEC tubes?? |
The tolerance is super tight on the housing I have seen so it might work if the Sony tubes are same/smaller (but not too much) than the P19/PT22s used in the 1209s. Even a few mm bigger would be a problem you probably need somebody to measure both tubes bare to figure out it it worked. I sold my last bare P19 so cannot help you there.
