Barco HDTV module
Hulio
Posted: Sat May 09, 2009 6:39 pm    Post subject: Barco HDTV module
Hello gents,
I've got a barco tri-level sync board (R762268T) for my BG808.It fits on the vertical deflection board and when intalled, it allows component HD directly on port 5.
The big deal is, adaptation of this board involves removal of three resistors (R28, R69, RR599) and one capacitor (C207) from the vertical deflection board (R7622685).
Does anyone knows if this mod has downsides too ? I mean, removing those components would give sync problems with some other inputs and sources ?
Stan
Ile
Posted: Sun May 10, 2009 10:10 am    Post subject: Re: Barco HDTV module
I highly doubt this, because projector (non s 808) still doesn't have decoder to chance component to rgb. It will work if your source can send rgb (sync on green) from component connectors, but "HDTV" board shouldn't be needed for this.
According to manual board is for RGB with tri-level sync, so board just chance old 90' style Japanise HD sync to normal. You don't get this style sync from modern sources.
It does look like that removing those components would cause problems with other sources.
You need external component to rgbhv (vga) transcoder and with that Barco doesn't need "HDTV" board.
Decibel
Posted: Sun May 10, 2009 11:13 am    Post subject:
hey Hulio Wink
I've a unused Vert. Defl.+sync board.
It was pulled from a BG808s/E
p.n. of the board is R769008/R769008s
This board have two little sub boards with these part numbers:
R762848 and R762728
.... are tri-level sync boards?
 Filesize:  293.78 KB
 Viewed:  5609 Time(s)
 Filesize:  331.96 KB
 Filesize:  230.23 KB
 Filesize:  258.66 KB
Domenico (Barco fan!)
Decibel
Posted: Sun May 10, 2009 12:07 pm    Post subject:
ooops
Hulio wrote:
R762268T
Decibel wrote:
R762848 and R762728
I have read wrong number, sorry Rolling Eyes
Hulio
Posted: Sun May 10, 2009 2:02 pm    Post subject:
Thanks for the info, Ile.If it does not add any value to the projector i wont bother installing it than.
@Decibel
Here is what HDTV module looks like
 Filesize:  118.48 KB
 Viewed:  5587 Time(s)
Posted: Sun May 10, 2009 4:23 pm    Post subject: Re: Barco HDTV module
Tri-level sync is what HDTV in North America uses but over a YPbPr connection. So the Japaneese used RGB with tri-level for their earlier HD?
aszego
Posted: Tue Oct 23, 2012 1:22 am    Post subject:
@Decibel
Hulio, do you still have the Barco tri-level sync board (R762268T) and would you consider selling it?
Andy
Hulio
Posted: Tue Oct 23, 2012 2:46 pm    Post subject:
Hello Andy,
Check your PM box.
Regards,
Stan
