daves123
| Posted: Fri May 08, 2009 12:33 am Post subject: NEC XG Green tube question |
Is the green tube in a NEC XG 135LC the same as the green tube in all XG models, and PG XTRAS? Or do the LC units use different tubes?
daves123
| Posted: Fri May 08, 2009 1:25 am Post subject: |
Yeah, i've looked at that chart. I've also read that the green tubes (and only the green) from the PG XTRAS are interchangeable with the XG models, but when I look at the chart, the xtras are listed as P16JLE, and the XGs are listed as P16LJE06 or
P16LJE07 or
P16LJE08
| Posted: Fri May 08, 2009 2:00 am Post subject: |
That is a misprint in the chart. The PG Extra tube is also a P16LJE.
daves123
| Posted: Fri May 08, 2009 2:20 am Post subject: |
The chart says that the xtra tube is a P16LJE, so i'm a little confused. Are the green tubes infact the same?
| Posted: Fri May 08, 2009 2:23 am Post subject: |
Yes, the green tubes are the same.
daves123
| Posted: Fri May 08, 2009 11:46 am Post subject: |
Thank you. Some of the info out there seemed contradicting and just wanted to clear it up.
| Posted: Sun May 10, 2009 12:31 am Post subject: |
No they are not the same.
The 06 and 07 model tubes, fitted to an XG, have an Extra KH grid.
To run an 08 tube in my XG I removed the KH resistor from the neckboard (the one from the KH pin to ground). I'm not certain if this was required, others haven't done this.
Also, the LC and AC housing are completely different. They can be swapped, but it is an ENORMOUS amount of very delicate work.
| Posted: Sun May 10, 2009 1:01 am Post subject: |
Mark. The PG Extra green tube is a P16LJE08. The XG's also use the P16LJE08. You yourself have also said that these tubes have been swapped without modification.
| Posted: Sun May 10, 2009 4:42 am Post subject: |
| macgyver655 wrote: | | Mark. The PG Extra green tube is a P16LJE08. The XG's also use the P16LJE08. You yourself have also said that these tubes have been swapped without modification. |
No I haven't.
I run a 08 myself in my XG. But I lifted one end of the resistor attached to the KH pin on the neckboard.
| Posted: Sun May 10, 2009 1:42 pm Post subject: |
| Mark_A_W wrote: | | macgyver655 wrote: | | Mark. The PG Extra green tube is a P16LJE08. The XG's also use the P16LJE08. You yourself have also said that these tubes have been swapped without modification. |
No I haven't.
I run a 08 myself in my XG. But I lifted one end of the resistor attached to the KH pin on the neckboard. |
Isnt this you?
| Description: |
| Filesize: |
204.83 KB |
| Viewed: |
10373 Time(s) |
| Posted: Sun May 10, 2009 9:16 pm Post subject: |
Ok, if you read it, you'll see I am unsure.
If you do it without removing the resistor, you are grounding G1, through a 3M3 resistor. Not sure if that is a good idea or not.
| Posted: Mon May 11, 2009 2:36 am Post subject: |
So I guess your final answer is your not sure. Lets see if we can find an answer with some facts. These facts are from NEC service manuals.
First lets see what tubes are used in what machines. All facts pertain to the green only for this issue.
6/9 PG EXTRA....P16LJE08HKA
XG750,1100,1350......P16LJE07HKA
XG751......P16LJE07HKA
XG1101,1351(LC's)......P16LJE06HKA
XG852.......P16LJE07HKA
XG1352(LC)....P16LJE06HKA
As you can see the PG Xtra uses an 08, XG non LC's use 07 and XG LC's use an 06.
So now lets look at the neck boards to see whats up. Pics will be attached below showing what projector the schematic is for. First, if we look at the PG Xtra schematic we see the (2) G1's are tied together, have a spark gap and then you can see the incoming G1 line.
Next we look at the 750,1100,1350 schematic. Huh, same design for the G1. Both tied together, spark gap and incoming line. But wait, thats an 07 tube. Same as the 08 tube. Guess that should be a swap no problem. Hmmm, but the 07 was also used in the 751 which the neck board has a different design with 2 amps and (1) G1 line through a resistor going to ground. So I guess the 07 tube will work with either type of G1 system design. So the 08 also works in the 1 amp neck board so it should also work in the 2 amp board.
Now the 751, 1101 and 1351 all use the same neckboard but the 1101 and 1351 use the 06 tube. So these tubes will swap no problem. Then we have the 852 and 1352 which is the same neckboard as the 751,1101,1351.
So when we put all this together, all these tubes should swap without any issues. I'll leave it at that unless any comments require further discussion.
Here are the diagrams:
| Description: |
| Filesize: |
153.34 KB |
| Viewed: |
10343 Time(s) |
| Description: |
| Filesize: |
132.27 KB |
| Viewed: |
10343 Time(s) |
| Description: |
| Filesize: |
324.67 KB |
| Viewed: |
10343 Time(s) |
| Description: |
| Filesize: |
139.41 KB |
| Viewed: |
10343 Time(s) |
| Posted: Mon May 11, 2009 6:02 am Post subject: |
There are three problems with what you just wrote...
1. The service manual is wrong in that area, it does not match reality.
2. Both LC and AC projectors had either 07 or 06 tubes, they even mixed and matched in the same projector. It doesn't matter as they are identical. My XG-751 came with 06's, contradicting your list. But it shows how useless "facts" from a NEC manual are.
3. Some XG's (at least in the US) were fitted with 08 tubes from factory. They came with a sticker saying to retube only with 08's. To me this may imply a different neckboard, or just a different white balance required, without seeing one, I cannot say. This is why I am unsure.
I do not trust those schematics as far as I can throw them. I know the XG version 1 schematic is wrong.
I don't have the version 2 service manual (852/1352). Is there any way you can upload that so I can download it?
| Posted: Mon May 11, 2009 2:31 pm Post subject: |
| Mark_A_W wrote: | There are three problems with what you just wrote...
Which manual do you mean since they are different and what exactly doesn't match?
If your talking about the red and blue tubes also then yes they did come new with 07 (RG) and 06 (B). My post stated I was discussing green only. Also unless you bought it new then a tube may have been changed and this could apply to all projectors. They are old enough to have had tubes changed. But if you were able to order new tubes from NEC then my chart applies. But let me just say that since they are all similar I wouldn't doubt that even NEC used different tubes then posted in the parts list. Point was, they are all the same.
If this is fact, this merely proves the point and remember the neck boards are the same G1 setup for the XTRA and XG xx0.
Have you actually ever seen this sticker or projector?
Again, whats wrong?
Sure mark, just PM me your email..... |
| Posted: Mon May 11, 2009 9:36 pm Post subject: |
All the first two XG manuals are wrong in the PIN area, I think. Certainly the xxx1 XG manual is wrong.
I don't have a loose neckboard to compare offhand, Mike P has them, but I should get some in the next few weeks. What's wrong is the KH grid details. Have you got an XG neckboard handy?
I haven't seen an XG factory setup for 08's, but Doug has. I trust Doug.
And the tube numbers are still wrong. Like I said, my XG came with 06's, including GREEN.
I will PM you my address (but it's a hundred mb isn't it?).
| Posted: Mon May 11, 2009 11:07 pm Post subject: |
| Mark_A_W wrote: | All the first two XG manuals are wrong in the PIN area, I think. Certainly the xxx1 XG manual is wrong.
Well if the xxx1 manual is wrong in this area then so is the xxx2 because they are identical in print (I didn't examine each and every part for a match).
I have an xxx0 in storage but I dont have any xxx1 or 2 neck boards to verify. But I, for sure would never say that a schematic could not be wrong. I have seen many, many and many prints that were incorrect.
I can neither confirm or deny but as I said this just more so confirms that these tube interchange no problem.
I didn't know that you bought your XG brand new from NEC...sorry.
I will PM you my address (but it's a hundred mb isn't it?). |
| Posted: Tue May 12, 2009 1:24 am Post subject: |
?Doug said the tubes won't swap?
I was not so sure, and then compared the real neckboards between the XG and Xtra, and I modded mine so the neckboard didn't have the (unused) KH connection with the 08 tube. I did this 4 years ago, so the exact details escape me.
I know of an XG-xxx0 running an 08 without mods, but no xxx2/xxx3 XGs. I also think that the G1 is grounded through that resistor,may be ok, may not be.
And no, I didn't buy it new, but it had not been retubed. It's easy to tell a retubed projector, the red glue (like nail polish) on the focus coils must be broken to change a tube.
| Posted: Tue May 12, 2009 2:08 am Post subject: |
What version is your XG?
| Posted: Tue May 12, 2009 2:27 am Post subject: |
It was a 751, now it is a 1101LC (sans extra fan and correct sticker).
