Marquee face plate separation from LC housing, how to?
Posted: Thu May 07, 2009 11:26 pm    Post subject: Marquee face plate separation from LC housing, how to?
Hi guys, I need to remove the face plate from a 9 inch LC housing so they can be anodized. I removed the screw's but the RTV holding them together is on there pretty good, i dont want to try to chisle them off as the aluminum is fragile.
I could leave them on but am afraid the screw holes will not fit the screw right after the process. Also it would probably cost more or during the process the two parts could separate unless I leave the allen screws in that hold the two together. Would that bond the screws to the holes? Or if After I try to remove them would the anodization chip off?
And any of you guys do that type of work, id rather give a CRT guy the business.
Posted: Fri May 08, 2009 12:34 am    Post subject:
Instead of going through all the trouble couldn't you just paint the part with epoxy based paint and be done with it?
Mr. Green
Posted: Fri May 08, 2009 12:38 am    Post subject:
Just out of curiousity, why are you doing this?
Can you use paint thinners to separate the glue from the aluminum (the real stuff in the metal container)?
Posted: Fri May 08, 2009 4:41 am    Post subject:
Chip. I dont trust the Epoxy based paint. If i have to remove the tube after all the trouble to install it cause the epoxy paint starts to melt or mix with the glycol
it would suck. And if the Anodization didn't hold up i dont think the paint will.
Mr. Green, I'll try the paint thinners , not sure if it will seep into the rtv, the two pieces are very tight.
And I need to do it because parts of the original anodizing has come off and it is now bare aluminum, Glycol eats at it and you get floaties and fungus easier.
Mr. Green
Posted: Fri May 08, 2009 4:55 am    Post subject:
I'm not sure it will work either, but "the good stuff" will usually dissolve most adhesives. I think the last time I used it on silicone it became soft, but I was able to cut it much easier. I haven't tried what you are doing though, so be careful.
phishin_ca
Posted: Sun May 10, 2009 5:59 pm    Post subject:
You could also just put bolts into all of the holes before you have it done. This will prevent them from getting filled. They definitely will not "stick" I wouldn't worry about them flaking when you remove the screws, but the surface may fillet around them.
bbfarmht
Posted: Sun May 10, 2009 6:05 pm    Post subject:
Instead of putting regular bolts in the holes, which would also get anodized. You could find nylon bolts. They would probably seal better and not get any anodizing in the threads.
Adam
Benjamin Franklin
Posted: Sun May 10, 2009 6:07 pm    Post subject:
I was thinking this as well. I am more concerned if the two pars separate , however i could leave the 4 large allen screws
in and then hope once i put the tube in the anodizing process did not loosen the RTV between the two parts. But if the RTV I will use to mount the tube glass to the newly anodized face plate is put on well, i wont need to worry about any glycol getting past that glass to faceplate seal.
jkruger
Posted: Sun May 10, 2009 7:02 pm    Post subject:
The anodizer has rubber plugs for threaded holes. They do it all the time. The guys I use charge something like 20 cents per hole.
Type II anodizing is not as durable as Type III, but it is less expensive. I would have it done with Type III.
That's what is used for saltwater exposure and environments similar to that.
