Best way to use a line doubler?? WHAT PROJECTOR? ;)
Advent Videobeam
Posted: Wed May 06, 2009 8:45 am    Post subject: Best way to use a line doubler?? WHAT PROJECTOR? ;)
The unit works great to reduce VHS TAPE NOISE
Last edited by Advent Videobeam on Thu May 14, 2009 9:06 am; edited 1 time in total
Posted: Wed May 06, 2009 12:43 pm    Post subject:
This might help:
http://www.curtpalme.com/CRTPrimer_17.shtm
Advent Videobeam
Posted: Tue May 12, 2009 3:29 pm    Post subject:
You can adjusts picture quality with unit
Last edited by Advent Videobeam on Thu May 14, 2009 9:07 am; edited 1 time in total
Posted: Tue May 12, 2009 3:38 pm    Post subject:
So your projector takes what? Component( YPbPr )? If so then you need an RGB to component transcoder like the Box1020.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10131.html
which projector are you trying to hook this up to?
Advent Videobeam
Posted: Tue May 12, 2009 3:45 pm    Post subject:
Has these units gone to the wayside for most people with newer PJs?
Last edited by Advent Videobeam on Thu May 14, 2009 9:08 am; edited 1 time in total
Posted: Tue May 12, 2009 3:53 pm    Post subject:
Your VCR is NOT component output methinks. It's a yellow RCA jack, right? That's COMPOSITE. Smile
Feed that into one of the BNC inputs on the doubler via an RCA to BNC adapter, then you take the RGBHV outputs of the doubler and feed it to the projector. THat's it.
Posted: Tue May 12, 2009 4:28 pm    Post subject:
Advent Videobeam wrote:
so this will be worth while to do with my videotape collection?
The VHS tapes could look a little better with the doubler than without, depending on the projector. By eliminating the 480i flicker and scan lines, the doubler will make the image a little more solid and brighter, but it won't be any sharper. VHS is still crappy VHS. 240 lines of horizontal resolution will never look great projected on a screen no matter what you do it. As long as your expectations aren't too high, you'll be happy with the results. Wink
What model projector are we talking about?
Advent Videobeam
Posted: Tue May 12, 2009 8:53 pm    Post subject:
So the max VHS horiz resolution is 240 Ecrabb?
Last edited by Advent Videobeam on Thu May 14, 2009 9:10 am; edited 2 times in total
Posted: Tue May 12, 2009 8:55 pm    Post subject:
YOu're not making things easy, are you? Smile
What projector are you using the doubler with?
You'll need to get an SVGA to 5 BNC cable to plug the output of the NEC into the 1020 box.. which you WILL need if you want to feed the line doubled signal into a component video input.
Posted: Tue May 12, 2009 9:23 pm    Post subject:
Provided your projector can handle it.
What model is your projector?
Posted: Tue May 12, 2009 10:25 pm    Post subject:
DUDE, apparently you can't read. See above. Mr. Green Mr. Green Mr. Green
Posted: Tue May 12, 2009 10:37 pm    Post subject:
Actually I was first so :p Laughing
SC asked before you too: Laughing
I was just trying to hamer the point home.
Gee, this would be a lot easier if we knew what projector he had Laughing
Posted: Tue May 12, 2009 10:38 pm    Post subject:
EDIT: Updated thread title. Laughing
Posted: Tue May 12, 2009 10:46 pm    Post subject:
Hey, by the way, I haven't read every post here, but what projector are you using? Very Happy
Posted: Tue May 12, 2009 10:47 pm    Post subject:
I hope it's not that VideoBeam in his avatar. I don't think those take anything past 480i.
donaldk
Posted: Wed May 13, 2009 1:50 am    Post subject:
There were units with Euro tuners!
Posted: Wed May 13, 2009 2:08 am    Post subject:
OK then 576i
Advent Videobeam
Posted: Wed May 13, 2009 11:01 pm    Post subject:
What is the besty PJ recommended for this setup, I'm looing for a mid grade system, not a higher end as some form members, the least heavy on tyhe wallet?
dturco
Posted: Wed May 13, 2009 11:20 pm    Post subject:
Dude do you have a projector? Or are you asking what Projector you should buy?
Please clarify.
http://www.hulu.com/firefly
Posted: Thu May 14, 2009 12:18 am    Post subject:
The best way to use a Line Doubler, is to tie it to something you don't want to drift away...like a boat.
We have Bluray now.
BLU
RAY
